![]() | Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Hello Pete and welcome....
Petewake Member Since: 21 Oct 2013 Location: Coleraine Posts: 11 ![]() ![]() ![]() |
Hi Mate, Yeah I have tried searching for Bluetooth and nothing. But will search around the forum for a while and see what I can find for sure.
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
There are quite a few posts on Bluetooth connection on here. Searching will bring most of them up. Just make sure you have a working BT module in the boot. The previous owner of my FFRR took his one with him |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Bluetooth was never available on the earlier cars, so it must have been added after. Its either using a BMW ULF module on the end of the black 54 pin connector in the boot (having been rewired) or its an aftermarket kit.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
If yours is fitted with BT as standard then you should have a "pairing" button at the front of the cradle in the centre console, under the arm rest.
Bluetooth was never available. As standard or an option on the cars with BMW electronics, pre-touchscreen.
Guys,
Bottom left of the third image looks like a Bluetooth ULF module.
As Budgie says, ULF is fastened vertically in the bottom left of your last picture.
Hey,
The voice control from the steering wheel works no worries if that is to do with the ULF module
The button on the steering wheel never worked for pairing with mine.
Thanks that is great info, I will have a look at those other posts and see if I can sort it.
Just a quick one,
