Home > My Range Rover > Detail by Harvey123
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Detail by Harvey123
I decided earlier in the week having seen the images from Gaz after Harvey123 performed a detail on one of his cars to get mine looked at.
Drove the 85 miles over to his in an easy drive this morning. Met up outside his house where he set to work. First wash a rinse and snow foam. then a rinse and a dry. (my sone and i wondered off to the park for this bit so it was done when we got back)
Out came the DA polisher and he set to work removing the light scratches and swirls marks I had. Although the car was in relatively good shape anyway it needed some attention here.
All I can say is what a terrific job he did. Finally finishing off with a seal so it should be protected for a few months at least. I only had my iPhone so the pics aren;t great quality but to say I was pleased as punch was an under statement. It looks marvellous.
Many Thanks Harvey.. Great to see you again and a stunning job you did. Very pleased mate..!!
I would highly recommend you to anyone of the forum who's full fat is need of some TLC.
 Ash
2016 SDV8 AB
Post #214520 5th Oct 2013 6:01pm
Harvey123
United Kingdom 2006 Range Rover Autobiography Td6 Java Black
Cheers ash
Glad you were happy with the job Thumbs Up Range Rover Autobiography Black Conversion
Post #214521 5th Oct 2013 6:06pm
comports
Sure am. I didn't rain on the way home which was a bonus so she was all tucked up in the garage last night and still looks clean this morning despite the 85 miles trip home..!
Thanks again! Ash
2016 SDV8 AB
Post #214626 6th Oct 2013 9:59am
Googsy
Super job good to see members using other members for services Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #214635 6th Oct 2013 12:09pm
Car looks great
You need some new wheel nuts though Whistle
Post #214643 6th Oct 2013 2:35pm
pld118
Did I read somewhere that you can buy wheel nut and/ or locking wheel nut covers?
Post #214646 6th Oct 2013 4:10pm
comports
I know. embarrassed to say I have brown nuts...!
need to change them but they are not that cheap if I remember rightly? Ash
2016 SDV8 AB
Post #214693 6th Oct 2013 6:15pm
correct Ash they are expensive..you could coat them with some silver spray until the right deal comes along.. ... - .- -.
Post #214699 6th Oct 2013 6:37pm
Aren't they the wrong nuts for the wheels ?
I thought it was only the pre-05 nuts that rusted.
With those wheels you should have the later nuts anyway and they are silver.
If you're running the wrong nut's then they are likely to shake themselves loose !
Post #214714 6th Oct 2013 6:59pm
that's a very valid point Alistair.. Shocked ... - .- -.
Post #214722 6th Oct 2013 7:04pm
comports
I must assume from the comments that the wheels are post 05..? The car is pre 05 (54 plate) Ash
2016 SDV8 AB
Post #214739 6th Oct 2013 7:48pm
comports
And if they are wrong - would these be the fellas I need
linky  Ash
2016 SDV8 AB
Post #214743 6th Oct 2013 7:53pm
correct on both counts.. Thumbs Up
for safetys sake i would undo one nut and check its shank size.. ... - .- -.
Post #214745 6th Oct 2013 7:53pm
Yep - those are ~2010 wheels - That assumes the wheels are genuine & not copies......
The thread for the nuts is the same, but the later wheels had a larger bore - so the old nuts fit, they're just too loose
Thread here
Basically you need the nuts to match the wheels & not the car.
Post #214746 6th Oct 2013 7:55pm
comports
Many thanks Stan and Alistair.
I will go ahead and order a set in the link (unless someone tells me they can be bought cheaper/better elsewhere) Ash
2016 SDV8 AB
Post #214747 6th Oct 2013 7:56pm
