Home > Technical (L322) > airbag / firing circuit fault can anyone help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
check connections under the seat first.. ... - .- -.
26th Sep 2013 6:13pm |
..then maybe have a read on these threads,
26th Sep 2013 6:16pm |
Jackofq300 Member Since: 11 Aug 2013 Location: Dart ford Posts: 45 |
thanks stan but connections under seat seem ok. |
26th Sep 2013 6:20pm |
had a look at your link mate and got some ideas i can try. so thank you.. its just the firing circuit 1 part i would like to find out about. |
26th Sep 2013 7:34pm |
thinking about that and i'd be worried that its something to do with the way the airbag goes off.. ... - .- -.
26th Sep 2013 7:44pm |
oh that does not sound good. surely there not designed so there could off at any time could they?? is it worth trying to get it disconnected? |
26th Sep 2013 7:49pm |
dunno mate, but i would get it seen by a garage .. ... - .- -.
26th Sep 2013 7:51pm |
ok thanks stan. im quiet new to this forum so do you think i should do another post stating firing circuit, to see if somone out knows anymore on the subject |
26th Sep 2013 8:00pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
It will be the slip ring in the steering coloumn usually... 2 plugs = 2 stage firing... So your fault will be with the wiring to plug one or two on the drivers airbag (usually a break in the slip ring wiring)
26th Sep 2013 8:05pm |
i've amended your title to include the firing circuit problem .. ... - .- -.
great thank you stan. what a great forum. time to buy a car sticker if think. |
26th Sep 2013 8:25pm |
btw, Craig does know his stuff... ... - .- -.
26th Sep 2013 8:26pm |
"ish" |
26th Sep 2013 8:29pm |
oh ok thanks graig. funny enough the chap i got the car from said he had a problem like that and he said he just cleaned the rings/connections up and the airbag light went out. but he said i should have no probs with it, but who knows. do you know roughly how much new parts would be from beadles? thanks again. jacko |
26th Sep 2013 8:34pm |
