![]() | Home > Maintenance & Mods (L322) > Need help with overheating 2006 HSE Jag 4.4 Petrol |
Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42 ![]() ![]() ![]() |
I'm searching the vast knowledge and experience of the forum and it's members for suggestions in my latest RR Adventure.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
Can i assume that there is a themostat in the cooling system and he has changed that?
^+1 |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
The remote water pump (the electric one )
Thanks for the replies.
I'm pretty sure that you have the engine oil to coolant heat ex-changer and it sits just below the transmission oil one. Both on the drivers side of the radiator. They are even identical as far as I could see. They are used to warm up the oil quicker to reduce emissions and then keep the temperature in check. The SC has an additional air to oil heat ex-changer.
Well I picked up the Rangie today and was told that the overheating after it was all put together was due to a thermostat failure. Just goes to prove that you guys are smarter than the average bear.
Thermostat |
The whine could be the tensioner wheel. The AC puts more load on it the belt and that could be the extra needed on top of the normal stuff to start the whine. MY 2010 5.0 SC Galway green and sand interior!!
Both tensioners were replaced within the last 6 months.
And what about the alternator ?? Or the waterpump (or was that replaced already ?).
The alternator was replaced already and I think the water pump is the only other pulley on the a/c belt. 2006 HSE |
See if you can pinpoint the whine in the waterpump area |
