Home > Maintenance & Mods (L322) > Need help with overheating 2006 HSE Jag 4.4 Petrol |
Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42 |
I'm searching the vast knowledge and experience of the forum and it's members for suggestions in my latest RR Adventure.
23rd Sep 2013 4:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
Can i assume that there is a themostat in the cooling system and he has changed that?
23rd Sep 2013 6:11pm |
^+1 MY 2010 5.0 SC Galway green and sand interior!!
23rd Sep 2013 6:15pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
The remote water pump (the electric one )
23rd Sep 2013 6:18pm |
Thanks for the replies.
23rd Sep 2013 8:41pm |
23rd Sep 2013 8:47pm |
I'm pretty sure that you have the engine oil to coolant heat ex-changer and it sits just below the transmission oil one. Both on the drivers side of the radiator. They are even identical as far as I could see. They are used to warm up the oil quicker to reduce emissions and then keep the temperature in check. The SC has an additional air to oil heat ex-changer.
23rd Sep 2013 9:46pm |
Well I picked up the Rangie today and was told that the overheating after it was all put together was due to a thermostat failure. Just goes to prove that you guys are smarter than the average bear.
25th Sep 2013 7:36pm |
Thermostat
25th Sep 2013 7:47pm |
The whine could be the tensioner wheel. The AC puts more load on it the belt and that could be the extra needed on top of the normal stuff to start the whine. MY 2010 5.0 SC Galway green and sand interior!!
25th Sep 2013 8:31pm |
Both tensioners were replaced within the last 6 months.
25th Sep 2013 10:29pm |
And what about the alternator ?? Or the waterpump (or was that replaced already ?).
26th Sep 2013 7:18am |
The alternator was replaced already and I think the water pump is the only other pulley on the a/c belt. 2006 HSE |
26th Sep 2013 1:44pm |
See if you can pinpoint the whine in the waterpump area MY 2010 5.0 SC Galway green and sand interior!!
26th Sep 2013 2:43pm |
