Home > Technical (L322) > Battery Charging Advice
Page 1 of 3 123>
hcire
United States 2006 Range Rover HSE 4.4 V8 Zambezi Silver
My Rover sat for eight or nine weeks without being driven or started. I know better Embarassed. Now I believe I need to charge the battery. I have read the procedures for battery removal and reconnection, but I have a few questions (probably silly) about vehicle access with the battery removed.
1) I believe the driver's door has a mechanical lock and will open without the battery. Is this correct?
2) Will the latch for the hood (bonnet for you gentlemen) operate with the battery removed, or is it an electronic mechanism?
3) Do I ned to worry about the pyrotechnic charge for the terminal post when connecting the charger?
Post #211864 23rd Sep 2013 11:51pm
RR2008HSE
I can only help you with 3. There are battery terminals to use under the bonnet. You don't attach anything to the actual battery because of the pyro charge. I'd recommend a getting a full charge BEFORE trying to start the vehicle. Charging a very low battery is very hard on the alternator, and they aren't cheap.
Post #211870 24th Sep 2013 1:30am
1 Yes
2 Yes
3 No Thumbs Up
Post #211883 24th Sep 2013 7:17am
The drivers door does have a mechanical lock, sadly they usually seize and you can't get in when such an emergency arises Big Cry
The bonnet is cable operated, you only need to get past that seized door lock to be able to pull the lever Laughing Laughing
When connecting the terminals try and do it without causing too many sparks Thumbs Up
Post #211932 24th Sep 2013 8:28am
If you have a tow bar and electrics of course you don't need to get into the car at all to charge the battery if the need arises.
Simply connect your battery charger to the appropriate connections on the towbar electrics.
Post #211937 24th Sep 2013 8:32am
hcire
I pulled the battery without incident, and the battery is now charging. Now I hope it takes a charge and there are no underlying electrical issues.
Thank you for the replies.
Post #212122 25th Sep 2013 1:29am
n1cktdv8
I have never heard of this before but it sounds pretty good. I have 13 pin and LR loom, can I simply get a spare 13 pin male and have 2 leads running from it ???... Is this where I put the car details and a bit about myself ?........
Post #212125 25th Sep 2013 5:05am
Have you seen this from our Glorious Leader ?
http://www.disco3.co.uk/shop/index.php?act...oductId=45 2008 MY Supercharged
Post #212130 25th Sep 2013 5:47am
n1cktdv8
I hadn't.....but I can make one of those !
Just need a wiring diagram and to be 100% positive it wont affect the genuine LR loom
Thanks for the link Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #212132 25th Sep 2013 5:56am
As long as you don't push more than 20amps into it I think you should be fine Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #212365 25th Sep 2013 10:41pm
Would it be possible to put a 3 pin plug onto that and charge the battery from the mains? Whistle
Post #212375 26th Sep 2013 6:47am
I wonder which would pop first... The rear fuse board or the battery.... Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #212414 26th Sep 2013 9:37am
wealy
How do I buy one of those? I guess it just plugs into a ctek?
Post #212874 28th Sep 2013 12:32pm
wealy
Or optimate type charger?
Post #212875 28th Sep 2013 12:35pm
wealy
Post #212877 28th Sep 2013 12:37pm
Page 1 of 3 123>
