Home > Technical (L322) > Battery Charging Advice
Page 2 of 3 <123>
Just click thru the ship like normal online shopping Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #212879 28th Sep 2013 1:01pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Ive bought one but it doesnt seem to work. Should I have power from pins 3 & 4 on the 12S socket?
Post #224312 21st Nov 2013 4:11pm
12 S socket, the white one.
Pin 4 +ve
Pin 3 -ve
Post #224319 21st Nov 2013 4:29pm
wealy
Should 4 be permanent live - even with ignition off? Mine isn't?
Post #224322 21st Nov 2013 4:40pm
Yes, although there is a fuse in the supply. Fuse blown or not in place?
Post #224323 21st Nov 2013 4:44pm
wealy
Any idea where the fuse is????
Post #224324 21st Nov 2013 4:45pm
Not on a 2010 I'm afraid. Sorry
Post #224326 21st Nov 2013 4:58pm
Rear fuse box there are 3 maybe 4 for the trailer sockets.
1 50amp fuse thats the forward most one of the 3 big fuses at the rear of the fuse box.
Then in the first highest row of 4 fuses the rear most one is for the trailer electrics and then there is one or two i think in the lower row of fuses Smile
20amp rating for the upper most one and then 5 or 10 amp for the other lower row ones IIRC Smile
That should help Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #224345 21st Nov 2013 6:24pm
wealy
Where is the fuse box?
Post #224425 21st Nov 2013 11:03pm
Open the upper and lower tailgate and it's under the access panel on the right hand side. Lift the plastic handle up and gently leaver away the top and then lift it out. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #224426 21st Nov 2013 11:16pm
wealy
Thanks
Too dark now
Will have a look on the morrow
Post #224429 21st Nov 2013 11:20pm
wealy
Just had a quick look - wow it's cold out there! All fuses are ok?
Big Cry
Post #224434 21st Nov 2013 11:32pm
There is also a diagram further to the rear of that panel that shows all fuse locations and is usually quite accurate per model variant Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #224436 21st Nov 2013 11:39pm
wealy
Yes
Can see that
All fuses ok???
Post #224438 21st Nov 2013 11:59pm
If they are all ok there and you've taken them out and checked them as sometimes they can look fine from the top but still have blown, then it's worth looking at the front fuse box in the glovebox in case one there has blown. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #224464 22nd Nov 2013 8:18am
Page 2 of 3 <123>
