![]() | Home > Technical (L322) > Time for FBH- what do I need to buy then? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
this might be of interest Patrick,
Nod Member Since: 20 Sep 2013 Location: Birmingham Posts: 6 ![]() ![]() ![]() |
Noddy here
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
Can't see anything under my bonnet. It's located in the passenger wheel arch under the battery. 2011 Range Rover Vogue SE 4.4 TDV8
Shows how much this "specialist" knows then!
Not done it myself but I understand that taking the wheel arch liner out is the easiest way if you need to access it. Like you, I believe all td6s have it.
Can't say I've heard the unit run, but I have seen the "pre-heating" message on cold mornings. |
Just need to enable the park heat function then. I used the iid tool. If it doesn't actually fire up for some reason, then that's a different issue altogether.......... 2011 Range Rover Vogue SE 4.4 TDV8
I think this specialist was assuming the FBH was in the same place as the Range Rover Sport. There was one on his ramp with no engine in, and that was located on the wheel arch passenger side |
Just had a quick look under the wheel arch but can't see anything resembling a FBH or any kind of exhaust? |
You have to take the plastic wheel arch liner out to see anything. Not sure where the exhaust comes out. Will be passenger side under the arch somewhere I'd imagine. 2011 Range Rover Vogue SE 4.4 TDV8
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
Got my original account working again now
You do not need to take the battery out:all you need to do is stick your head under the car behind the front wheel and look for the stainless steel exhaust pipe that ends more or less flush with the wheel arch liner.
Oh - do you mean the glow plug "pre-heat" before you start the motor that only appears on very cold days? That has nothing to do with the FBH, tho.... ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
It says pre heat in the instrument cluster. Not the orange glow plug symbol. I could hear the fbh running after it. I did a thread about this at the time, which was a bit inconclusive if I remember right,
