Home > Technical (L322) > Time for FBH- what do I need to buy then?
Page 3 of 4 <1234>
this might be of interest Patrick,
http://www.fullfatrr.com/forum/topic12516.html?highlight=t91+gsm ... - .- -.
Post #210041 13th Sep 2013 12:03pm
Nod
United Kingdom 2002 Range Rover Vogue Td6 Zambezi Silver
Noddy here
I've been locked out of my account as I've changed my email so I've had to register again until my account is active
I've taken my car to a specialist today to activate FBH in testbook. He looked under the bonnet and told me I didn't have the heater installed. I thought all TD6's had them?
Post #211373 20th Sep 2013 7:20pm
mjdronfield
Can't see anything under my bonnet. It's located in the passenger wheel arch under the battery. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #211375 20th Sep 2013 7:24pm
Nod
Shows how much this "specialist" knows then!
I'll go back next week and inform him of its location!
Post #211377 20th Sep 2013 7:34pm
mjdronfield
Not done it myself but I understand that taking the wheel arch liner out is the easiest way if you need to access it. Like you, I believe all td6s have it.
On cold mornings do you get a pre heater message in the instrument cluster and you can hear the fbh running to help warm up the cabin. Sounds like a little jet engine 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #211378 20th Sep 2013 7:40pm
Nod
Can't say I've heard the unit run, but I have seen the "pre-heating" message on cold mornings.
Post #211379 20th Sep 2013 7:45pm
mjdronfield
Just need to enable the park heat function then. I used the iid tool. If it doesn't actually fire up for some reason, then that's a different issue altogether.......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #211380 20th Sep 2013 7:52pm
Nod
I think this specialist was assuming the FBH was in the same place as the Range Rover Sport. There was one on his ramp with no engine in, and that was located on the wheel arch passenger side
Post #211383 20th Sep 2013 8:00pm
Nod
Just had a quick look under the wheel arch but can't see anything resembling a FBH or any kind of exhaust?
Post #211392 20th Sep 2013 8:53pm
mjdronfield
You have to take the plastic wheel arch liner out to see anything. Not sure where the exhaust comes out. Will be passenger side under the arch somewhere I'd imagine. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #211394 20th Sep 2013 8:59pm
Andy
Got my original account working again now
I'll whip the battery out this week and the under tray and see if it's there
Post #211589 22nd Sep 2013 7:57pm
SteveMFr
Site Sponsor
You do not need to take the battery out:all you need to do is stick your head under the car behind the front wheel and look for the stainless steel exhaust pipe that ends more or less flush with the wheel arch liner.
There is no 'Pre-heat' message in the display w/o park heat activated as your FBH is running as an auxiliary heater. And there is no 'auxiliary heat' message.
Unless someone has removed it, you DO have an FBH. All diesel RR L322s have them.
Cancel your 'specialist' and sell your AllComms and you've financed an IIDTool. You'll have park heat, numerous other CCF options, and much more extensive diagnostics to boot.
Noddy, please get this thing sorted. I am starting to get claustrophobic-like-panic-feelings when I see your multiple FBH threads come up. Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #212220 25th Sep 2013 12:59pm
mjdronfield
Rolling with laughter
I enabled my FBH park heat with the IIDTool. You have to enable it in 2 places in the menus and then do a instrument cluster reset.
I got the Pre-Heat message come up without my Park Heat activated. Definately the case. Came on when I started the car on cold mornings.
If you physically want to see it, you will have to remove the arch liner. Removing the battery tray won't help.
As Steve says, the exhaust is in the wheel arch somewhere.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #212260 25th Sep 2013 3:43pm
SteveMFr
Site Sponsor
mjdronfield wrote:
:I got the Pre-Heat message come up without my Park Heat activated. Definately the case. Came on when I started the car on cold mornings.
Oh - do you mean the glow plug "pre-heat" before you start the motor that only appears on very cold days? That has nothing to do with the FBH, tho....
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #212270 25th Sep 2013 5:01pm
mjdronfield
It says pre heat in the instrument cluster. Not the orange glow plug symbol. I could hear the fbh running after it. I did a thread about this at the time, which was a bit inconclusive if I remember right,
You chaps know the firmware better than me though..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #212273 25th Sep 2013 5:49pm
Page 3 of 4 <1234>
