![]() | Home > Technical (L322) > Speedo not working, no ABS, DSC.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Driving home from work, all seemed well.........did a 90 degree left turn out of a T junction and thought that the steering wheel suddenly resisted movement slightly more than usual, and then freed up to be much lighter than normal.
I hate to say it but I would try a battery disconnect and reconnect before anything else. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Could be a duff ABS sensor, E39 BMWs do the same. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
the 90 degree turn might have dis-lodged or broken the ^ abs sensor.. ... - .- -.
As the abs is the first in line of all the sensors if it has a fualt, it triggers off all the other sensors.
Many thanks folks.
MMmm Failed to get to work this morning.
Mr Kipling Member Since: 01 Apr 2013 Location: North West Posts: 3 ![]() ![]() ![]() |
Hi, first time posting but I had a very similar fault on my 07 TDV8 last night.
TDV8s and Td6s are very different electrically, so don't necessarily assume it's an ABS issue. |
My trusted garage can't collect it until tomorrow morning, so prob won't find out any more till perhaps Monday.
Tbh I'm trying to find somewhere to start ATM!!
No problem Mr Kipling. At least yours is driveable.
I've had to take the day off too! I commute into Derbyshire so I have to find the fault ASAP so the same thing doesn't happen again. It's driveable for now but feels a little like Russian roulette......!
Quick update. Garage looked at the car today, and as suspected, there is no signal from the rear left ABS sensor regarding wheel rotation.
