Home > Technical (L322) > Speedo not working, no ABS, DSC.... |
Driving home from work, all seemed well.........did a 90 degree left turn out of a T junction and thought that the steering wheel suddenly resisted movement slightly more than usual, and then freed up to be much lighter than normal.
19th Sep 2013 5:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I hate to say it but I would try a battery disconnect and reconnect before anything else. |
19th Sep 2013 5:35pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Could be a duff ABS sensor, E39 BMWs do the same. |
19th Sep 2013 6:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
the 90 degree turn might have dis-lodged or broken the ^ abs sensor.. ... - .- -.
19th Sep 2013 6:35pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
As the abs is the first in line of all the sensors if it has a fualt, it triggers off all the other sensors.
19th Sep 2013 7:47pm |
Many thanks folks.
19th Sep 2013 8:05pm |
MMmm Failed to get to work this morning.
20th Sep 2013 8:51am |
Mr Kipling Member Since: 01 Apr 2013 Location: North West Posts: 3 |
Hi, first time posting but I had a very similar fault on my 07 TDV8 last night.
20th Sep 2013 9:56am |
TDV8s and Td6s are very different electrically, so don't necessarily assume it's an ABS issue. |
20th Sep 2013 10:00am |
My trusted garage can't collect it until tomorrow morning, so prob won't find out any more till perhaps Monday.
20th Sep 2013 10:15am |
Tbh I'm trying to find somewhere to start ATM!!
20th Sep 2013 10:17am |
No problem Mr Kipling. At least yours is driveable.
20th Sep 2013 10:44am |
I've had to take the day off too! I commute into Derbyshire so I have to find the fault ASAP so the same thing doesn't happen again. It's driveable for now but feels a little like Russian roulette......!
20th Sep 2013 11:01am |
Quick update. Garage looked at the car today, and as suspected, there is no signal from the rear left ABS sensor regarding wheel rotation.
23rd Sep 2013 4:38pm |
