![]() | Home > Technical (L322) > Flat Key |
If the battery in the key is flat, I expect it to take a lot longer to charge. Suggest to use the spare and main key together for a while to allow the spare to charge (it has to be in the ignition during driving for that), until it starts working again. I would suspect several hours of charging before it has a decent charge and after that maybe alternate the keys every week.
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 ![]() ![]() ![]() |
Hi ebajema,
You'll need the main key for a bit to switch the alarm of I think |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
I may be a bit slow here but how does a key charge itself unless there is a -ve and -ve connection on the key or it uses an inductive loop charging system?
It's an inductive charging system. If you have a look at the workshop manual for the 2007-2009 in PDF, you'll see the charging coil shown. MY 2010 5.0 SC Galway green and sand interior!!
I thought this was about the key for your flat. |
resync the key |
