Home > Wheels & Tyres > 285/50/20 - Will they fit - Any Help Please ?
wishy
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi Guys
Quite new to the forum so Hello !
Just looking for some help. I ve just bought a MY2011 60plate 4.4tdv8 SE and looking to put some winter tyres on. I have left over from the last car a very new set of Cooper Zeon's that are 285/50/20. I know the standard fitment is 255/50/20 but I could just do without another set of tyres clogging up my garage.
I had a puncture yesterday so whilst the mobile guy was at my house we tried fitting one of the 285's and it fitted on the car (and looked mean!) but was very close to the suspension on the inside. In reality not close to the suspension but there is a v small 1" spike plastic spike coming down from the gas strutt.
So 2 questions - does anyone know what the 1" spike bit is for as it seems a bit redundant
and also - has anyone fitted this size before ? I think I saw a post saying they had but had put 5mm spacers on ?
Also I am slightly worried that if the tread fills up with mud it might knock this 1" plastic spike off ?
Thanks in advance Smile
Jonny
ps - insurance company have no issue with it as they are still 20" tyres so not a modification apparantly and a not has been placed on file.
Post #209534 11th Sep 2013 11:23am
GregMilner
Australia 2012 Range Rover Westminster TDV8 Fuji White
Interesting question Jonny...I'm about to take delivery of a 2012 TDV8 L322, it's fitted with 285/40/22 wheels/tyres. So overall probably a bit bigger diameter than yours, I'll have to look and see if it's knocked off that spike you're talking about!
Post #209543 11th Sep 2013 12:30pm
i had 295/45/20 on my td6 with no clearance problems but my tyres were on RRS wheels which have more of an offset and a larger width.
your speedo will be out as well,
i would consider getting a set of RRS rims and sticking the 285's onto them, you could use these in the winter and your current ones for the summer. ... - .- -.
Post #209550 11th Sep 2013 12:44pm
wishy
Thanks Greg it would be interesting.
Stan, I will look out for some 20" RRS wheels but do wonder if a simple spacer might solve it. Surely, there is a calculation that someone alot smarter than me can do to work out the difference of the offset between the two and then the size spacer required ?
Alot easier and cheaper to store a spacer in my garage than some more wheels and tyres etc !!!
Regards
Jonny
Post #209552 11th Sep 2013 12:52pm
spacers are an alternative certainly but they cost about £200 new..there are some used ones on ebay as well..they tend to be 30mm for each one so that will give you plenty of clearance and of course a better 'stance' look.... ... - .- -.
Post #209554 11th Sep 2013 12:59pm
GregMilner
Hey Stan where did you find that tyre size calculator?
Post #209557 11th Sep 2013 1:04pm
wishy
Hi Stan
I found http://wheelspacers.uk.com/ who do 3,4,5,6,7&10mm spacers tailor made for the RR and they are made in germany and shipped to the UK for £65 for 4 spacers. I was hoping a 5/6/7mm spacer would be ok. I think 30mm would push the tyre into problems on the other side of the wheel arch.
I think they are relatively simple piece of metal but have the correct centre bore rather than getting a universal one.
I need to measure the inside of the nut to check enough threads are left to actually lock the wheel on aswell.
I will try and post a pic of the 1" plastic nib when it stops raining
Regards J
Post #209563 11th Sep 2013 1:45pm
wishy
This is the part sticking down towards the tyre that might get knocked off ? For some reason it has yellow chalk/paint on it ?
Any ideas ?
Cheers
Post #209618 11th Sep 2013 7:29pm
Mr Tee
I cut mine off , my winters are theses bad boys : http://www.fullfatrr.com/forum/topic14523.html
Post #209625 11th Sep 2013 8:21pm
wishy
Cheers Mr Tee
Did you do the wheel arch modification mentioned in the other post - below the fuel filler ?
Is that plastic 1" think just where they were injection moulded then ?
Cheers
Post #209628 11th Sep 2013 8:39pm
Mr Tee
Yup, right at the bottom of the arch liner, I'll take a photo over the weekend if you like.this is them beside my 22's
Post #209642 11th Sep 2013 10:35pm
wishy
No Wonder I am having issues ! A pic would be great.
Post #209777 12th Sep 2013 12:38pm
wishy
Hi Stan
I have come across these which are off a 60 plate supercharged. Do you happen to know what offset they would be compared to my 60 plate Vogue se. Or does it have to be off a RRS ?
http://www.fullfatrr.com/gallery/albums/us...b_rr20.jpg
Thanks
Post #209781 12th Sep 2013 1:05pm
if they are 20'' and off a fullfat the offset will be the same as yours.. ... - .- -.
Post #209786 12th Sep 2013 1:11pm
wishy
Thanks Stan, I was worried you were going to say that !
Post #209790 12th Sep 2013 1:18pm
