![]() | Home > Technical (L322) > [Mechanical] Handbrake adjustment- How To |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Here is the excerpt from the L322 Workshop Manual
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
This is great, thanks for posting.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
No they weren't glazed up on mine when I took the discs off to replace them. Lots of dust and muck inside though. The "cog" seems to catch on the lower spring preventing it from turning.
@ The Brains Trust
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Thanks for that - mine has a full dealer service history too - mustn't be part of their checks...
If you want a comprehensive manual on these braking systems go over to Disco3 and search for "Bodsy's Brake Bible".
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
Mine needs taking up a bit. Which way do you have to move the cog ? Push it upwards till it stops ?
When I did mine I had both wheels off the ground.
Cheers.
OK...Obtained axle stands earlier this week and have attempted, and aborted, adjusting the handbrake.
I wasn't totally happy getting the other side up and resting it all on the 2 points of the stands. I was also unable to see down the hole for the cog. Decided would best be done by the garage with the proper kit. So where is the best point to support the car ? Thanks. 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Do you know of anyone with a set of orange Axle Stand for sale by chance? |
I tend to use the trolley jack with a flat wood block under the point where your stand is, when car is on the ground this is nice and "level". This allows to get the car to a height to get the axle stand under the jacking point for support.
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Ah. OK. Makes sense. Many thanks.
