Home > Technical (L322) > [Mechanical] Handbrake adjustment- How To |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Gentlemen IMPORTANT!!!!!! When you want to remove your rear drums/disks, it's IMPORTANT you back off the adjusters first!!!
8th Sep 2013 9:07am |
8th Sep 2013 9:08am |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Good advice Craig, it seams like common sense but I could easily see myself or another member having what is described in the firm as a " brain fart" and just trying to rip these off.
8th Sep 2013 9:14am |
8th Sep 2013 9:18am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
i was reversing off my drive when i heard a horrible grinding and scraping noise and when i looked at the rear wheel, one of the brake shoe retaining pins was working its way out from between the rear brake disc and the metal cover which wasn't good.
25th Jan 2014 4:35pm |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 101 |
Just an addition.
3rd Nov 2015 10:06am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
So when the handbrake shoes are correctly adjusted at the brake end, what's the expected travel of the handbrake lever in the cabin - how many clicks approx from 'off' to 'handbrake fully applied'?
7th May 2019 10:47pm |
8th May 2019 6:43am |
Thanks for the info, Nemmi69.
9th May 2019 2:33pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Would someone please explain how the hand break self adjustment works, or supposed to work. Eddie the eagle watch out 👀 |
12th May 2019 12:06pm |
