Home > Maintenance & Mods (L322) > Brake Disc Change |
No, I gave up and just put the new pads in. There comes a point where my time is more valuable than just paying someone to do it for me. I spent the weekend detailing instead! |
1st Jun 2010 7:30am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
New pads on old discs? Nothing wrong with that, but ideally you should have waited till the new discs were fitted, so that they "mate". 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
1st Jun 2010 1:05pm |
I generally get 3 sets of pads to a disc - but this will be the 4th so there is a bit of a step, but they seem to have bedded in ok.
1st Jun 2010 1:19pm |
Keep an eye on your discs. They'll need to come off immediately if you should see this:
3rd Jun 2010 9:21am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Mine will have shiny new discs and pads by tomorrow!
3rd Jun 2010 9:52am |
I bit the bullet and booked the RR into the garage to get the discs changed. I also needed to get the NSF CV boot replaced because it had split so I thought it would make sense to get the discs done at the same time….
22nd Jun 2010 9:49am |
Speaking of which, why does nobody make a set of high quality braided hoses for th FFRR? I know a lot of FF drivers would not really care but some of us enthusiasts and drivers of the older L322's might since a lot of us do maintenance ourselves. I have found a place who will make them up but I would have to buy original ones for them to copy. Bit costly that. |
22nd Jun 2010 11:00am |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Get a set of a scrapper
22nd Jun 2010 11:57am |
X5 Braided hoses should be fine shouldnt they?
22nd Jun 2010 12:14pm |
Really?? an X5? I know they share some common parts but I don't know how far that goes. |
22nd Jun 2010 2:22pm |
"Common Parts" It would take less time to list the parts they don't have in common. For example, the front brake pads fit: E46 99-07. 325 i, 330 ci, 330 d, M3 3.2 E38 94-01. 725 TDI, 728 i, 730 D, 730 i, 735 i, 740 D, 740 i, 750 i E39 98-03. M5 X3 04-07. 2.0 i, 2.0 D, 2.5 SI, 3.0 D X5 01-07. 3.0 i, 3.0 D, 4.4 i, 4.6 is, 4.8 is RANGE ROVER MK 3 02-07. 3.0 TD6, 3.6 TD8, 4.2, 4.4 So, you have the same pads in a Range Rover as you do in a 3 series that weighs half as much! |
22nd Jun 2010 2:29pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Thanks for the links noddy, hoping my front discs come off OK . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
29th Jun 2010 9:23am |
I've done a few hundred miles on these now so they should be bedded in and they definately seem to have less fade. However slowing from speed (80 to 50) seems to have a fair bit of wobble, but not sure if this is wheel balancing that's out as it doesnt happen all the time.
29th Jun 2010 12:49pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Not wanting to cause alarm dan - but from your photos, it does not look like the pads are applying even contact to the discs - the discs show several different contact 'bands' with quite a large area on the outer edge of the disc not looking as though it is being touched by the pads?
29th Jun 2010 5:45pm |
