Home > Maintenance & Mods (L322) > CV Gaiter Clip |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7841 |
When I had the RR MOT'd earlier this week, the chap pointed out that the clip on one of my front CV gaiters was not tight enough, and that grease was seeping out.
30th Aug 2013 4:44pm |
I would like to know too.... |
30th Aug 2013 5:02pm |
Think I've just answered my own question, using the video here ;
30th Aug 2013 5:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If you have trouble crimping a cable tie is more than adequate and very easy to fit. |
30th Aug 2013 5:25pm |
THe Video shows how to fit but what about removing/adjusting? |
30th Aug 2013 5:30pm |
I just assumed I could crimp it some more and it would tighten enough.
30th Aug 2013 5:32pm |
Well, I managed to borrow some pincers and nipped the clip up enough to stop it moving without the gaiter. If I try and spin the clip now, the whole driveshaft turns.
31st Aug 2013 11:45am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Jubilee clip? |
31st Aug 2013 11:46am |
I'd just come back to this thread to mention a jubilee clip......
31st Aug 2013 11:52am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
As long as the cable tie is tight and has a good grip on the boot it shouldn't come off as some aftermarket cv boot kits come with cable ties and not the metal clamp type like you have.
31st Aug 2013 12:06pm |
A jubilee clip is what I've used on the inner end of my CV gaiter. I've got the proper tool and still mashed up the proper clip... |
31st Aug 2013 12:09pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
I am having trouble with my front CV boot straps. Unfortunately I took the old ones off and fitted new aftermarket ones that I cannot get to seal. Tomorrow I will be double strapping it with the new one next to the first but 180 degrees to it. If that doesnt work then maybe one of those wire tie devices would be my next option.
1st Sep 2013 8:16am |
Got back from a 1800km trip over the weekend and during the trip noticed the inner front guards acquiring a smattering of cv grease. Not wanting to look under the car while away today I put it up on the hoist to see the drivers side had emptied itself of grease and while the passenger one was down to about half. Also everything was covered in grease which was a bit of a give away and the clamps had loosened though when fitted they had no movement.
10th Sep 2013 10:16am |
