Home > Maintenance & Mods (L322) > CV Gaiter Clip
mjdronfield
CV Gaiter Clip
When I had the RR MOT'd earlier this week, the chap pointed out that the clip on one of my front CV gaiters was not tight enough, and that grease was seeping out.
Just been under the car, and I can turn the metal clip round with some pressure with my fingers.
Does anyone know how to tighten it further ?
I know there is a tool available, but buying one seems a bit overkill if I've only got to nip it up a bit.
Many thanks
Mark
OK....I did choose photo and added it..........will try the old way.....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #206851 30th Aug 2013 4:44pm
I would like to know too....
Post #206863 30th Aug 2013 5:02pm
mjdronfield
Think I've just answered my own question, using the video here ;
Now to see if I have one of those tile cutter type things........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #206866 30th Aug 2013 5:06pm
If you have trouble crimping a cable tie is more than adequate and very easy to fit. Wink
Post #206871 30th Aug 2013 5:25pm
THe Video shows how to fit but what about removing/adjusting?
Post #206874 30th Aug 2013 5:30pm
mjdronfield
I just assumed I could crimp it some more and it would tighten enough.
No idea how to remove properly if you want to replace....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #206875 30th Aug 2013 5:32pm
mjdronfield
Well, I managed to borrow some pincers and nipped the clip up enough to stop it moving without the gaiter. If I try and spin the clip now, the whole driveshaft turns.
Unfortunately, what you can't see from the picture, is that the smaller clip on the other end is not even on the gaiter and is loose on the shaft. I managed to pry the end of it up with a screwdriver and unclip it, but can't squeeze it enough when it the correct position to get it to clip together.
I've just took it off and put on a massive cable tie. Will have to see how we go.
That was the same garage that damaged my rear bumper when they last had it. Suffice to say I haven't used them fo a while now.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #206973 31st Aug 2013 11:45am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Jubilee clip?
Post #206974 31st Aug 2013 11:46am
mjdronfield
I'd just come back to this thread to mention a jubilee clip......
As its the smaller end, I could prob find one that would fit, but a mechanic mate of mine has said as they are heavier, you can sometimes have balance issue as it spins round.
See what he's saying, but not sure you'd notice it on a TD6........
To be fair, I expect the cable tie to come off, and I'll end up back at a different garage or trying a jubilee clip.
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #206975 31st Aug 2013 11:52am
RCusden
Wales
As long as the cable tie is tight and has a good grip on the boot it shouldn't come off as some aftermarket cv boot kits come with cable ties and not the metal clamp type like you have.
Roger
Post #206980 31st Aug 2013 12:06pm
Richcl
A jubilee clip is what I've used on the inner end of my CV gaiter. I've got the proper tool and still mashed up the proper clip...
Post #206981 31st Aug 2013 12:09pm
A warning about jubilee clips on CV gaitors.
When the front wheels are on any sort of lock the screw part of the jubilee clip can catch the rubber boot and tear it. Then you have a bigger job to do.
A cable tie should stay on for years provided it's been put on correctly.
Post #206985 31st Aug 2013 12:22pm
ahebron
New Zealand
I am having trouble with my front CV boot straps. Unfortunately I took the old ones off and fitted new aftermarket ones that I cannot get to seal. Tomorrow I will be double strapping it with the new one next to the first but 180 degrees to it. If that doesnt work then maybe one of those wire tie devices would be my next option.
http://www.clamptitetools.net/
Adrian VW Amarok 2014 Highline auto
Post #207101 1st Sep 2013 8:16am
ahebron
New Zealand
Got back from a 1800km trip over the weekend and during the trip noticed the inner front guards acquiring a smattering of cv grease. Not wanting to look under the car while away today I put it up on the hoist to see the drivers side had emptied itself of grease and while the passenger one was down to about half. Also everything was covered in grease which was a bit of a give away and the clamps had loosened though when fitted they had no movement.
Fortunately the Clamptite tool I ordered last week arrived yesterday so I was well armed to tackle the job after an initial experiment with a wooden hammer handle. Using the Clamptite on the cv is a two man job as you have to keep tension while your assistant adjusts the loops on the opposite side, well it was in my case but I am sure experience will make it easier. The wire pulls up nice and tight leaving absolutely no movement on the band or boot which is good. So fingers crossed this will work and end my weeks of leaking cv boots but if that fails I have another product to fall back on
http://www.dixonvalve.com/product/4001.html
which I picked up in Whangarei on the weekend. Confused
Post #209287 10th Sep 2013 10:16am
