Home > Technical (L322) > BONG!! Transferbox Neutral Gremlin
Scared the life out of me this morning Shocked
A bit of history. Car been sat for five days, then driven 50 miles, no problems. Sat for 2 days, but started to pump up tyre, no problems.
Set off to work this morning after about a mile and a half, having got up to 60mph and set Cruise, message centre started bonging at me with "TRANSFERBOX NEUTRAL" about 10 times in quick succession, then stopped. No triangles left in message centre. No problems with drive or power. Continued onto work for another 20 miles, switched off and no reprise of message.
Just one of those things I guess....... Yawn .
Post #202435 5th Aug 2013 12:17pm
didnt you do something with your transfer box Tim?
maybe the plug has come loose? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #202445 5th Aug 2013 1:06pm
Not touched it for over a year, nor tried to go Low/High in that time. (although I did do the HDC the other week?) .
Post #202465 5th Aug 2013 3:07pm
Was a gremlin, must have scared it off, because it hasn't revisited. .
Post #204532 17th Aug 2013 3:50pm
witchcraft or voodoo?.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #204545 17th Aug 2013 6:10pm
Meerbusch
Hallo, had the same!! problem last month, installed new battery, and from this day on, the display didn´t show that message. But I want to try LOW HIGH, and it din´t switch..., so I took a hammer and pushed him to the gearbox, WOW, now best function, better to test it each week... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #204576 17th Aug 2013 9:54pm
Ah, well, it came back again this morning. Exactly the same MO: car sat for five days, then driven 50 miles. car then sat for two days, then driven @ 1.5 miles @ 7.30am. Happened in exactly the same place on the road on the way to work. Only got five bongs this time.
So note to self:
drive car more often after leaving for five days, try starting work at a different time, or take a different route to work Whistle .
Post #205783 26th Aug 2013 4:25pm
Bit of high low switching and liberal application of a hammer to the car, not necessarily to the transfer box, you dont want to anger it after all... There is nothing that can't be fixed with a hammer😜😜
Post #205786 26th Aug 2013 4:36pm
Battery I think.
Post #205787 26th Aug 2013 4:37pm
IWC1
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
What Gary said,
I would check the battery too. Had the same warnings (and more) myself, all resolved with a new battery.....and alternator!
Andy
Post #205870 27th Aug 2013 8:52am
The fact that happens after leaving the car unused for 5 days is a clear indicator its the battery. Get a new one first before you get the hammer out. Maybe worth checking alternator output too. Thumbs Up
Post #205872 27th Aug 2013 9:03am
As gaz said i reckon. What battery have you got?
If its a 90AH rated one it could spell trouble if the weather gets cold this year?
Maybe spend sometime with it on a ctek charger, i've bought one for this very reason and the fact i have a shed load of batteries in the garage that i could breath better life into helps as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #205878 27th Aug 2013 9:22am
I know what you are saying about the battery, but it doesn't make sense.
No problems starting up after five days, and no issues for fifty miles.
The bong comes two days later in the morning, in the same place, after starting up fine. Might take the dowsing rods out, just to check for leylines or force fields Laughing
Its a Varta 110ah battery with the high crank.
I'm not overly concerned, just sharing a gremlin Very Happy
And where do I hit it with a hammer Meerbusch? .
Post #206008 27th Aug 2013 9:03pm
Meerbusch
Must hit the hammer to the motor shape of the transferbox motor, and you must test (like I do) the motor each week, or two days the week, mostly the drivers only drive in high range, therefore the low range becomes lazy .... had never used the low range about two years! Rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #206013 27th Aug 2013 9:20pm
Joe next time before you go out see what voltage your actually getting at the battery and don't forget after cranking it drops another chunk as well so could be a gremlin where the system voltage gets back to a certain level? Maybe monitor it on the dash ? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206024 27th Aug 2013 9:53pm
