Home > Technical (L322) > BONG!! Transferbox Neutral Gremlin |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Scared the life out of me this morning
5th Aug 2013 12:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
didnt you do something with your transfer box Tim?
5th Aug 2013 1:06pm |
Not touched it for over a year, nor tried to go Low/High in that time. (although I did do the HDC the other week?) .
5th Aug 2013 3:07pm |
Was a gremlin, must have scared it off, because it hasn't revisited. .
17th Aug 2013 3:50pm |
witchcraft or voodoo?.... ... - .- -.
17th Aug 2013 6:10pm |
Ah, well, it came back again this morning. Exactly the same MO: car sat for five days, then driven 50 miles. car then sat for two days, then driven @ 1.5 miles @ 7.30am. Happened in exactly the same place on the road on the way to work. Only got five bongs this time.
26th Aug 2013 4:25pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
Bit of high low switching and liberal application of a hammer to the car, not necessarily to the transfer box, you dont want to anger it after all... There is nothing that can't be fixed with a hammer😜😜
26th Aug 2013 4:36pm |
Battery I think. |
26th Aug 2013 4:37pm |
IWC1 Member Since: 11 Jan 2013 Location: suffolk Posts: 18 |
What Gary said,
27th Aug 2013 8:52am |
The fact that happens after leaving the car unused for 5 days is a clear indicator its the battery. Get a new one first before you get the hammer out. Maybe worth checking alternator output too. |
27th Aug 2013 9:03am |
As gaz said i reckon. What battery have you got?
27th Aug 2013 9:22am |
I know what you are saying about the battery, but it doesn't make sense.
27th Aug 2013 9:03pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 294 |
Must hit the hammer to the motor shape of the transferbox motor, and you must test (like I do) the motor each week, or two days the week, mostly the drivers only drive in high range, therefore the low range becomes lazy .... had never used the low range about two years! Rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
27th Aug 2013 9:20pm |
Joe next time before you go out see what voltage your actually getting at the battery and don't forget after cranking it drops another chunk as well so could be a gremlin where the system voltage gets back to a certain level? Maybe monitor it on the dash ? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
27th Aug 2013 9:53pm |
