Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
As these are often asked for I cut and paste them out, thanks mainly to Thrasher for this info.
29th May 2010 11:34am |
Switch it off, pull the key out, run away!
1st Jun 2010 3:43pm |
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 |
Thank you!.. it's ok, the car blew up 2 minutes later!
1st Jun 2010 7:19pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Interestingly I was playing with this last night and although my TV picture is all-right normally in this test mode it's rubbish , also I didn't have to re-cycle the ignition to get out , I went in to revers to park and the reverse camera took over then it went back to the test screen so I pressed the Radio/Tv hard key and all of the functions came back . 2008 MY Supercharged
2nd Jun 2010 6:57am |
TV is rubbish at first but if you press the PAL button it goes back to satisfactory. Discovery 4 HSE
2nd Jun 2010 7:24am |
doublejay Member Since: 08 Nov 2009 Posts: 131 |
No joy for me. 2005 with Touchscreen and MOST. plus 07-08 satnav disc upgrade.
3rd Jun 2010 10:32am |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 |
Nor me??2007 MY If you have nothing nice to say,say nothing at all. |
3rd Jun 2010 5:14pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 787 |
Thank you, it works! Maybe it should be mentioned that after pressing the touchscreen for 5 seconds, nothing shows up, you just go and press the nav plastic button for another 5 seconds and the keypad appears on the screen… |
14th Jun 2010 3:40pm |
yawlboy Member Since: 02 Mar 2010 Location: RAK Posts: 53 |
works brilliantly, thank you |
15th Jun 2010 8:53am |
A pre-touch screen friend asks if/how can this be done on his... |
17th Jun 2010 4:47pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Adam, I'm still not too clear on which menu I need to be in initially . On my touchscreen, if I turn the audio on and then select the DVD/TV button it will immediately put the dvd/tv on in the left upper side of the screen with the channels listed to the right of the display. Is it in this screen where I hold for 5secs? Steve
21st Jun 2010 5:19pm |
Right here goes , and I'm rubbish at long explanations .
21st Jun 2010 7:48pm |
Hi Axle. Thanks for the explanation, I have now accessed the diagnostics successfully.
21st Jun 2010 10:48pm |
I find it strange that you can select 3 different screen formats for the rear view camera but they aren't a normal menu option? I quite like the 'wide 2' display format and I tried leaving the reverse camera on when on the motorway and it was actually quite useful to take a quick look when lane changing as it enabled me to see the blind spots around the 'd' pillars quite easily. Also, I did note that you can actually enable this whilst on the move (not that you want to really). Steve
3rd Jul 2010 5:48pm |
