![]() | Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
As these are often asked for I cut and paste them out, thanks mainly to Thrasher for this info.
Switch it off, pull the key out, run away!
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 ![]() ![]() |
Thank you!.. it's ok, the car blew up 2 minutes later! |
Interestingly I was playing with this last night and although my TV picture is all-right normally in this test mode it's rubbish , also I didn't have to re-cycle the ignition to get out , I went in to revers to park and the reverse camera took over then it went back to the test screen so I pressed the Radio/Tv hard key and all of the functions came back . 2008 MY Supercharged
TV is rubbish at first but if you press the PAL button it goes back to satisfactory. Discovery 4 HSE
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
No joy for me. 2005 with Touchscreen and MOST. plus 07-08 satnav disc upgrade.
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Nor me??2007 MY |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 800 ![]() ![]() ![]() |
Thank you, it works! Maybe it should be mentioned that after pressing the touchscreen for 5 seconds, nothing shows up, you just go and press the nav plastic button for another 5 seconds and the keypad appears on the screen… |
yawlboy Member Since: 02 Mar 2010 Location: RAK Posts: 53 ![]() ![]() ![]() |
works brilliantly, thank you |
A pre-touch screen friend asks if/how can this be done on his... |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Hi Adam, I'm still not too clear on which menu I need to be in initially . On my touchscreen, if I turn the audio on and then select the DVD/TV button it will immediately put the dvd/tv on in the left upper side of the screen with the channels listed to the right of the display. Is it in this screen where I hold for 5secs? Steve
Right here goes , and I'm rubbish at long explanations .
Hi Axle. Thanks for the explanation, I have now accessed the diagnostics successfully.
I find it strange that you can select 3 different screen formats for the rear view camera but they aren't a normal menu option? I quite like the 'wide 2' display format and I tried leaving the reverse camera on when on the motorway and it was actually quite useful to take a quick look when lane changing as it enabled me to see the blind spots around the 'd' pillars quite easily. Also, I did note that you can actually enable this whilst on the move (not that you want to really). Steve
