Home > Maintenance & Mods (L322) > Bulge in door - intermittent reverse cam
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all,
Still new to the forum so apologies if I go astray or this is covered elsewhere.
I'm looking at purchasing a 2006/55 SC that appears to be in quite good condition.
One of the things I picked up though was what looks like a bulg in the lower section of the rear drivers side door.
I couldn't make out any other damage, scratches or marks just a strange bulge in the "plastic" section??
Any ideas what this could be and are these panels easy to fix/replace??
Also the reversing cam is very temperamental and refuses to work most of the time.
Again is this an easy fix or replace?? I've noted on some forums retrofitting non OEM cameras, I just wasn't sure if this was a known problem or not.
Thanks in advance.
Mike
Post #200488 24th Jul 2013 11:12am
kruger2002
When I say I noticed a bulg I meant a bulge!! Embarassed
Mike
Post #200489 24th Jul 2013 11:13am
The lower door panels are plastic clip on jobbies, so yes, you could pop it off, see what the bulge is and potentially replace. Discovery 4 HSE
Post #200492 24th Jul 2013 11:24am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
It would be easy enough to remove the inner door panel to see if there is any damage to the door panel behind. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #200493 24th Jul 2013 11:24am
Here you go:
 Discovery 4 HSE
Post #200494 24th Jul 2013 11:27am
^^ what they said re the bulge and the rear view camera isnt the best quality and some have repaired or replaced ..how to is in the wiki.. ... - .- -.
Post #200496 24th Jul 2013 11:27am
kruger2002
Wow
What service Bow down
Is there any particular bonding tape to use when putting back together?
Post #200600 24th Jul 2013 5:12pm
Mostly just watch out you don't break the clips as they are pretty brittle at best , if you need tape 3M double sided tape will do Thumbs Up
Post #200601 24th Jul 2013 5:15pm
paneldamage
It's best to get the door card off and squeeze the white nylon clips inwards and outwards, just pulling at the panel/ clips can break the thinnest part of the panel where the clip sits.... If it does, a blob of non- setting body sealant will replace an odd missing clip. For future ref -- On the rear doors, there is a little screw right at the trailing edge as well as the clips. Thumbs Up
Post #200618 24th Jul 2013 6:10pm
kruger2002
Thanks guys.
All sounds manageable so might have another look at this one.
Post #201967 1st Aug 2013 10:25pm
