Home > Maintenance & Mods (L322) > Bulge in door - intermittent reverse cam |
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 |
When I say I noticed a bulg I meant a bulge!!
24th Jul 2013 11:13am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
The lower door panels are plastic clip on jobbies, so yes, you could pop it off, see what the bulge is and potentially replace. Discovery 4 HSE
24th Jul 2013 11:24am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
It would be easy enough to remove the inner door panel to see if there is any damage to the door panel behind. Tom
Here you go:
24th Jul 2013 11:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
^^ what they said re the bulge and the rear view camera isnt the best quality and some have repaired or replaced ..how to is in the wiki.. ... - .- -.
What service
24th Jul 2013 5:12pm |
Mostly just watch out you don't break the clips as they are pretty brittle at best , if you need tape 3M double sided tape will do |
24th Jul 2013 5:15pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
It's best to get the door card off and squeeze the white nylon clips inwards and outwards, just pulling at the panel/ clips can break the thinnest part of the panel where the clip sits.... If it does, a blob of non- setting body sealant will replace an odd missing clip. For future ref -- On the rear doors, there is a little screw right at the trailing edge as well as the clips. |
24th Jul 2013 6:10pm |
Thanks guys.
1st Aug 2013 10:25pm |
