Home > Technical (L322) > Access switch not working
dalziel
2003 Range Rover SE Td6 Epsom Green
EAS is fully functional including auto drop to m'way height but switch on door to select access height ahead of parking does nothing. Tried it stationary in P and N also just to check it wasn't speed related. Is it fused?
Post #199712 20th Jul 2013 12:31pm
possibly fused , you'd have to look on rave/topix for that but most probably a loose connection on the switch ..do the windows work ok? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #199719 20th Jul 2013 12:58pm
dalziel
Yep, all windows work and switches for mirrors and rear window isolation working.
Post #199729 20th Jul 2013 2:04pm
easiest thing to do would be to disconnect the battery for an hour...if this doesnt work then its the door card off to check for loose connections ..i would have thought that the whole switch gear would be on one fuse and hence your windows are working then its not the fuse..[might be wrong though].. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #199734 20th Jul 2013 2:36pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Have you had a look at the plug on the back of the switch. Mine wasn't working and upon removal of the door card I discovered the plug had disconnected from the switch. Simples & handy little feature.
Post #199747 20th Jul 2013 5:38pm
dalziel
done battery - no joy. Door card off and switch connector unplugged then re-plugged. No joy. Did notice that all wiring looms behind door card had insulation tape halfway along wiring runs. Is that normal?
Post #199748 20th Jul 2013 5:50pm
