Home > Technical (L322) > Access switch not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
possibly fused , you'd have to look on rave/topix for that but most probably a loose connection on the switch ..do the windows work ok? ... - .- -.
20th Jul 2013 12:58pm |
dalziel Member Since: 11 May 2013 Location: Harrogate Posts: 57 |
Yep, all windows work and switches for mirrors and rear window isolation working. |
20th Jul 2013 2:04pm |
easiest thing to do would be to disconnect the battery for an hour...if this doesnt work then its the door card off to check for loose connections ..i would have thought that the whole switch gear would be on one fuse and hence your windows are working then its not the fuse..[might be wrong though].. ... - .- -.
20th Jul 2013 2:36pm |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
Have you had a look at the plug on the back of the switch. Mine wasn't working and upon removal of the door card I discovered the plug had disconnected from the switch. Simples & handy little feature. |
20th Jul 2013 5:38pm |
done battery - no joy. Door card off and switch connector unplugged then re-plugged. No joy. Did notice that all wiring looms behind door card had insulation tape halfway along wiring runs. Is that normal? |
20th Jul 2013 5:50pm |
