![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
RRUK - yes you can use the IID tool to switch off the TPMS warnings, I have done it on my VSE. Just put the tool in and tell the ECU's that TPMS is not installed, you don't need to remove any of the sensors 56 TDV8 Vogue SE
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
When is 2.18 out and will you manage to get PCM petrol adaption reset added in time? |
I believe Christian is planning to add this - but will have to check to make sure. |
Awesome! I might have to buy an IIDTool BT version just to say thanks |
Well today i became an IID Tool Beta tester, which is just fantastic. Obviously the first thing I did was play with the new features, and they are great. The Control I/O stuff which allows you to test mirrors and windows without having to use the switches is handy. However the best part for me was the new Service/Test stuff which lets you reset Engine and Transmission adaptions as well as run a fuel priming. My car now feels silky smooth and the occasionally lumpy idle has ceased as well as driving like an absolute dream. You're all gonna love it! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 ![]() ![]() |
being able to reset the gearbox adaptations sounds good.. |
Runs fuel through the system to purge any air bubbles that might be there. Not sure it did much for me, but is nice to know it's a diagnostic option. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I've got the beta version of IIDTool BT and will be changing tyres/TPMS senders soon and would like to know - does the new beta software allow programming of new TPMS module when fitted to spare? .... According to Topix the system will learn new modules automatically except for the spare - then you have to fit it as a running wheel for 15mins above 12mph or code it into the module?
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Looking to order one of these, but wondered when the latest version is going on general release?
depends if you want an interface on a bluetooth compatible device or on the dash readout..but note only certain devices are supported with the BT at the moment..
Al Hornby Member Since: 19 Mar 2013 Location: Horsham West sussex Posts: 18 ![]() ![]() ![]() |
Hi Guy's.
if its available then it should be there for sale... ... - .- -.
BT IIDTool is still only available to beta testers - I was fortunate to be invited onto the program and have one. |
