![]() | Home > General > Just what you don't need at the start of a road trip |
F'in dead battery.
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
I know the feeling rebuilt the compressor reset the fault codes working suspension. Lasted two day now have to go on holiday in the ford |
Well, got the old one out. Pretty easy actually - with access mode (thanks for the tip - but I knew about it), and by standing on the wing to lift it out.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
sorry to hear that Kurt...hope the trip goes ok.. |
The battery is FIAMM by the way. It's had a tough time starting her sometimes when I had a dodgy injector, but it's still only 15 months old.
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
What's this bonnet access mode? I assume its something that gets the bonnet a good bit higher than normal for better access to the battery location? 4.4 TDV8 Vogue Baltic Blue MY11 |
^ Yes. You undo the clips on the gas struts and pull the struts off. Lift the bonnet higher and there's a lever to slide out that holds the bonnet in a vertical position. Can't see you getting the battery out any other way, though doubtless someone has.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Hope the trip goes well. |
Thanks. I hope you have a good trip and everything goes to plan. 4.4 TDV8 Vogue Baltic Blue MY11 |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Here's the Wiki thread on the access mode: http://www.fullfatrr.com/forum/topic16561.html |
Thanks for the top tip. I actually tried the extended bonnet opening thing out today, only I completely removed the strut clips. Didn't realise you could just slide them down.......I know now though.
A tip for you guys... Take the end off from the car then tuck the shocker in under the bonnet carpet cover |
Dusseldorf, Antwerp, Calais, Kent, North London, Reading, Gloucester, London, Gloucester, Birmingham, Uxbridge, Kent. Calais, Unknown so far, home. Trip going well so far, although I have to call Craig later where he'll tell me all the expensive things that are wrong with my RR. ![]() ![]() |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Access mode is not needed - , have replaced sofar inexcess of 5 batteries (have lost count)- its just how you swing the damm thing in ![]() |
