Home > General > Just what you don't need at the start of a road trip |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
F'in dead battery.
12th Jul 2013 6:56pm |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
I know the feeling rebuilt the compressor reset the fault codes working suspension. Lasted two day now have to go on holiday in the ford
12th Jul 2013 7:12pm |
Well, got the old one out. Pretty easy actually - with access mode (thanks for the tip - but I knew about it), and by standing on the wing to lift it out.
12th Jul 2013 7:39pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
sorry to hear that Kurt...hope the trip goes ok.. ... - .- -.
12th Jul 2013 7:43pm |
The battery is FIAMM by the way. It's had a tough time starting her sometimes when I had a dodgy injector, but it's still only 15 months old.
12th Jul 2013 7:47pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
What's this bonnet access mode? I assume its something that gets the bonnet a good bit higher than normal for better access to the battery location? 4.4 TDV8 Vogue Baltic Blue MY11 |
13th Jul 2013 12:29am |
^ Yes. You undo the clips on the gas struts and pull the struts off. Lift the bonnet higher and there's a lever to slide out that holds the bonnet in a vertical position. Can't see you getting the battery out any other way, though doubtless someone has.
13th Jul 2013 12:57am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Hope the trip goes well.
13th Jul 2013 6:36am |
Thanks. I hope you have a good trip and everything goes to plan. 4.4 TDV8 Vogue Baltic Blue MY11 |
13th Jul 2013 12:19pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Here's the Wiki thread on the access mode: http://www.fullfatrr.com/forum/topic16561.html |
13th Jul 2013 9:13pm |
Thanks for the top tip. I actually tried the extended bonnet opening thing out today, only I completely removed the strut clips. Didn't realise you could just slide them down.......I know now though.
14th Jul 2013 12:32am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
A tip for you guys... Take the end off from the car then tuck the shocker in under the bonnet carpet cover That way, when you drop it back down, they dont scrape the wings (EASILY DONE) |
14th Jul 2013 10:00am |
Dusseldorf, Antwerp, Calais, Kent, North London, Reading, Gloucester, London, Gloucester, Birmingham, Uxbridge, Kent. Calais, Unknown so far, home. Trip going well so far, although I have to call Craig later where he'll tell me all the expensive things that are wrong with my RR. |
16th Jul 2013 7:23am |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
Access mode is not needed - , have replaced sofar inexcess of 5 batteries (have lost count)- its just how you swing the damm thing in |
16th Jul 2013 9:18am |
