Home > In Car Electronics (L322) > TDV8 gremlins |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3839 |
I have had both the same problems.
27th Jun 2013 8:24am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Top tip!!!
27th Jun 2013 8:32am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
I also had the alarm problem but the bonnet sensor was not the culprit; it was a faulty "body tilt" module. Cost about £150 to replace. Bonnet switch clean and mod is very cheap to try first though! Graham
27th Jun 2013 8:34am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Double press on key on that MY should disable interior sensors only. |
27th Jun 2013 8:58am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Get a fly inside your car and once its locked the fly can set off the interior sensor. Annoying. Discovery 4 HSE
27th Jun 2013 9:20am |
Right...cleaned switch, and glued a little rubber pad on under side of bonnet, don't know if it's cured the problem, as not very sunny today. Also adjusted the rear tailgates, as these seemed a bit loose when shut. |
27th Jun 2013 11:18am |
Supershuttle
30th Jun 2013 6:03pm |
30th Jun 2013 6:20pm |
