Home > In Car Electronics (L322) > TDV8 gremlins
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
TDV8 gremlins
Hi all
Now had the car a couple of months, and overall, I am really pleased with it.
But....there are a couple of electrical gremlins, that I have no idea how to rectify,
(1) parking sensors, play up from time to time, constant beeping, flashing light, it does this irrelevant of weather conditions I.e. wet or dry.
(2) alarm, when car is sitting outside in the sun, alarm will keep going off, and its not particularly hot here at the moment.
Can you lock the car without setting alarm? Have tried pushing button twice, that didn't work.
Any ideas? Visit to main dealer is not an option here.
Steve
Post #196399 27th Jun 2013 8:19am
supershuttle
I have had both the same problems.
Not got round to the parking sensors yet but the alarm on mine was an easy fix, just cleaned the switch under the bonnet and also stuck a rubber foot (I had from an old computer) to the underside of the bonnet where it touches when closed so it engages a bit further.
Apparently it's a common "feature" Rolling with laughter
HTH Geoff
Post #196402 27th Jun 2013 8:24am
SFM
Top tip!!!
Going out to the garage to have a look now!
Thanks
Post #196404 27th Jun 2013 8:32am
A1GSS
I also had the alarm problem but the bonnet sensor was not the culprit; it was a faulty "body tilt" module. Cost about £150 to replace. Bonnet switch clean and mod is very cheap to try first though! Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #196406 27th Jun 2013 8:34am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Double press on key on that MY should disable interior sensors only.
Post #196410 27th Jun 2013 8:58am
Get a fly inside your car and once its locked the fly can set off the interior sensor. Annoying. Discovery 4 HSE
Post #196413 27th Jun 2013 9:20am
SFM
Right...cleaned switch, and glued a little rubber pad on under side of bonnet, don't know if it's cured the problem, as not very sunny today. Also adjusted the rear tailgates, as these seemed a bit loose when shut.
Post #196429 27th Jun 2013 11:18am
SFM
Supershuttle
Thanks so much for the tip, been hot and sunny here all day, and alarm hasn't gone off once.
Cheers mate
Post #197021 30th Jun 2013 6:03pm
A1GSS
Another forum winner...! Graham
____
Post #197025 30th Jun 2013 6:20pm
