Home > Maintenance & Mods (L322) > '06 on headlamp mounting plastic piece part number please.
johnboyairey
hi i am gathering parts to do a 06 on front end conversion. i bought a pair of secondhand front headlamps, and have got virtually all the other parts, BUT my lamps came without the top finishers. only two 'holes'
if you have an '06 on car, when you open the bonnet, you will see the slam panel, and to each side a black plastic piece above the headlamps, with a cut out semicircle shape in them. that hold the lamps to the slam panel. about 12 inches wide, 4 inches deep.....with a pair of fold over hooks on top. so the headlamps bolt to this top piece. if you can see a part number on this top piece only, i would be most grateful for the nunbers(S) left and right. ta...
i have stumped 'DAN at duckwoth' parts with this, and there is no 06 on car in his yard at present. -2010 on cars are different without this top piece.
Post #196707 28th Jun 2013 8:18pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think you will find you cant buy the parts.
I believe they come with the lights as a complete unit.
Maybe try a few breakers.
Post #196710 28th Jun 2013 8:25pm
johnboyairey
that is possibly correct, and would be a right PITA! i will have to make the aforesaid mount as a temporary fitment. with some sheet metal and a hammer. but if any of you can see a part number on the top plate, or if you have one off the car, maybe underneath. please.
Post #196718 28th Jun 2013 8:51pm
johnboyairey
interestingly, the part is NOT on the picture of the headlamp in the headlamp section, or the slam panel section! (microcat) D'oh!
Post #196721 28th Jun 2013 9:01pm
They are definitely not available to buy and only come with the headlamps...
Post #196724 28th Jun 2013 9:20pm
johnboyairey
DRAT! AND DOUBLE DRAT! Sad
Post #196733 28th Jun 2013 9:57pm
PaulB
Maybe get onto the seller and explain that they are not complete.
Post #196741 28th Jun 2013 10:23pm
