Home > General > South Manchester - recommend me a garage (willing to travel)
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
My MOT is due at the end of the month, so I'm taking the opportunity for a service and some preventitive maintenance!
I bought the car with a full Main Dealer service history 12 months ago and had it serviced at Guy Salmon Stockport (convenient more than anything else). They didnt impress and Williams seem uninterested on the telephone (and both are far too expensive!!), hence I'd rather find an indy who cares about their reputaiton and that I can trust!
List of work which needs doing below - recommendations please!!
Full Service
MOT (due 30th June)
Inspect and replace rear brake lines as required (advised corroded when serviced by a Main Dealer last year)
Inspect and replace both rear shock absorbers as required (both showed signed of having leaked oil when fitting new tyres recently….)
Replace rear upper and lower hub bushes
Check front upper/lower arm bushes, droplinks and ARB
Grease gear selector linkage
Change fluid in front/rear diffs and transfer box
Read error codes and to find out which wheel sensors are causing an intermittent TPMS problem, if required fit replacement sensors (I have four spare sensors) If still not working correctly, turn off! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #193027 10th Jun 2013 8:25am
campaj1
hunters in chester have upped their game according to reports...
Post #193029 10th Jun 2013 8:43am
TugRR
If you can travel a bit further -
http://www.dls-uk.co.uk/
I've been going there for 20+ years - top notch
Thumbs Up Where do you go after one of these . . . ?
Post #193032 10th Jun 2013 9:05am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
FourPlus4 in Leeds are excellent if no one recommends anywhere closer
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #193038 10th Jun 2013 9:32am
pld118
Re: South Manchester - recommend me a garage (willing to tra
Exclamation
Post #193050 10th Jun 2013 10:15am
Green Oval in stockport are reportedly very good, although they tend to do more older LR's they are fully capable with the new ones and are always fully booked 2-3weeks in advance Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #193055 10th Jun 2013 10:28am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
A1independant at Fernhill st Bury did me some good work on my last FFRR and seem dedicated to the marque. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #193063 10th Jun 2013 11:09am
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Hi,
Been recommended A1 in Bury Lancs by a 59 plate Disco owner.... (but not used yet as only had the FF 1 month)
http://www.a1-landrover-specialists.co.uk/
I also have used Lords Motors in Heywood. (They do all types of cars) The guy has a P38 and only does the what is required, and reliable but not the cheapest
Trev.
Post #193070 10th Jun 2013 12:47pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Doug Dransfield,
Stocksbridge
On the other side of Woodhead Pass from you
Post #193623 12th Jun 2013 9:23am
Rotorboater
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bournville
I use AJR in Oldham, Ask for Allister. They do loads of RR in the area and have all the right tools, they have done my previous car for the last 5 years and I never had a problem with their work and they charge about 1/2 main dealer prices.
A J R Motor Engineering
Address: Whetstone Garage, Clyde St, Oldham OL1 4HT
Phone:0161 624 1047
Post #193633 12th Jun 2013 9:50am
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
If you're willing to travel I can recommend Nicolsons at Bixter Garage in Shetland. Rolling with laughter Rolling with laughter
Post #193744 12th Jun 2013 5:50pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I'll go along with pld118 - I use Stratstone Bury and Barrie is always helpful, as are the service staff. They always try to do me a good deal when I need work done, also, I have the 3yr service plan (which includes free MOTs) which works out at £186 per service (incl vat).
Must be good if PLD118 is in Falkirk and travels all the way to Bury to have his car looked at!!! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #193789 12th Jun 2013 10:00pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
+1 for Stratstone at bury. Still the same staff from rockside and all very helpful. They also beat the specialists service quote for me so may be worth some haggling! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #193807 13th Jun 2013 5:15am
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
I got a quote from the local independent specialist in Bury for an oil and filter change and pollen filter change as well as a health check as I'm going to pick the vehicle up this week.
Anyway, based on one of the posts above, I emailed Barrie at the official Land Rover dealer in Bury and they've agreed to match the price! Going to get booked in next week.
Post #197158 1st Jul 2013 10:27pm
GraemeC
Thank you all for the recommendations
I went to AJR in Oldham - its convenient and Alister knew what he was talking about on the phone!
http://www.ajrmotorengineering.co.uk/
Very happy with the work - full service (inspection 2), MOT, new rear brake lines (advisroy at last main dealer service, quoted over £500 to replace!), investigate TMPS (initially fixed by clearing error codes, 2 weeks later it has broken again Censored ), investigate air con pressure loss and rear door leak - all for £600
Car is running perfectly, I'll certainly be using AJR again Mr. Green 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #199032 16th Jul 2013 7:57am
