Home > In Car Electronics (L322) > Disable interior alarm sensors by key fob?? |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
With miine you lock it with the remote then press it again and a wee red light comes on on the dash for a second. The dog is fine in the car then.
29th May 2013 10:50pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
not sure why the difference then.
30th May 2013 8:52am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
With the key turn the key in the drivers door lock twice within 10 seconds towards the rear of the car
30th May 2013 11:35am |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 294 |
Mine is a TDV8 07 and to put it into no internal sensors mine says lock once as normal wait a second or so and press lock again. No sound from the car but alarm has never gone off ever when set like that with the dogs in the car. It is not quick succession for mine but a moment in between both. Good luck |
30th May 2013 2:14pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
i am the same on both my TD6 and TDV8 i press the lock button twice and i leave the dogs in the car no problem!!
30th May 2013 5:19pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
page 29 in my manual says -
30th May 2013 7:16pm |
On a slightly different note, can you turn off the alarm with the key in the door?
30th May 2013 8:15pm |
right... I'm going to have a good play (coooeerrr ) with my locks
30th May 2013 8:50pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
You should also disable sensors when you take your FFRR on ferries or transporters.
30th May 2013 9:22pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
You'll know if its worked - the red light on the mirror will stay lit for around two seconds. That's what mine does. As has been said- arm the car normally, then press the lock button again and you should see the above. |
1st Jun 2013 6:53am |
Nope No amount of double pressing has got this to work. Only going through the vehicle settings on the dash board TFT display.
2nd Jun 2013 7:00am |
well, I have the official answer and its quite opposite to what you may logically think.
3rd Jun 2013 11:07am |
MML Member Since: 01 Mar 2013 Location: Europe Posts: 47 |
Never tried it, but I think it's the other way around... MML |
4th Jun 2013 4:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
i think you may be right MML... ... - .- -.
4th Jun 2013 5:14pm |
