Home > Maintenance & Mods (L322) > Brake calipers
Phil H
Wales 2004 Range Rover HSE Td6 Adriatic Blue
Brake calipers
Just found that my osr caliper is binding. Question is, is it worth buying a seal kit or get new caliper. Tried various sites today for cost of a caliper, only reply I had was 'previously owned' (£72.00 delivered). Anybody know approx. cost for new replacement?
Post #177233 12th Mar 2013 8:13pm
ebajema
Dutch dealer price was 70 Euro ex VAT with return of the old one. I replaced both at the same time. MY 2010 5.0 SC Galway green and sand interior!!
Post #177234 12th Mar 2013 8:27pm
Phil H
Thanks for that, trying to find a localish supplier.
Post #177235 12th Mar 2013 8:34pm
I got a front one on ebay for £45 with a £15 exchange charge. Search for X5 calipers usually a fair bit cheaper. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #177237 12th Mar 2013 8:59pm
Phil H
Thanks Rob, will have a look. Not many replies on this question though, am I asking an obvious question?
Post #177422 13th Mar 2013 8:20pm
Not worth buying the seal kit as the pistons will be rusted to the extent they are no longer of use. There are a couple of companies who will make new pistons from stainless steel, but it is a lot cheaper to fit new calipers
Post #177423 13th Mar 2013 8:22pm
BrianC
New calipers all the way Thumbs Up
Post #177424 13th Mar 2013 8:28pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Perfect excuse to fit some brembos Smile
Post #177427 13th Mar 2013 8:46pm
Phil H
New cliper fitted (british car parts - £94ish delivered), should have changed pads, bit didn't. OSR still getting hot. Replaced pads as old ones, due to excees heat, had lost the backing. Took it for a hard braking test drive, all ok.
Next day drove about 15 miles to collect my mother and take her to airport. Checked temperature at 15 miles, nice and cool. Drove to airport and back to home, appprox. 40 miles, osr hot again. Drove to the hay-on wye festival yesterday, forgot to check. On return to home (approx. 40 miles) both rears about the same temperature.
Question is, can the ABS/HDC cause an intermitant problem?
Post #190713 26th May 2013 8:54pm
Got mine off the bay with no exchange for about £45-50 IIRC Smile
Not an easy job with caked on bolts but not too bad compared to some other ones Sad
And at least they arent wind back pistons... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #190734 26th May 2013 10:13pm
ABS could cause an issue but you would feel it grabbing as it was doing it...
Did you clean the mating surfaces when you put the caliper on?
Its always worth putting new discs and pads on tbh
There are some discs on the bay for £25 brand new at the minute and a set of pads for the right calipers should be about the same. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #190735 26th May 2013 10:18pm
Budgie
It's also worth removing the disc and checking the parking brake shoes.
Mine had a load of cr@p inside the disc and one of the shoes had delaminated. Wink
Post #190746 26th May 2013 11:36pm
