![]() | Home > Maintenance & Mods (L322) > Brake calipers |
Dutch dealer price was 70 Euro ex VAT with return of the old one. I replaced both at the same time. MY 2010 5.0 SC Galway green and sand interior!!
Phil H Member Since: 17 Oct 2010 Location: Monmouthshire Posts: 34 ![]() ![]() ![]() |
Thanks for that, trying to find a localish supplier. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I got a front one on ebay for £45 with a £15 exchange charge. Search for X5 calipers usually a fair bit cheaper. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks Rob, will have a look. Not many replies on this question though, am I asking an obvious question? |
Not worth buying the seal kit as the pistons will be rusted to the extent they are no longer of use. There are a couple of companies who will make new pistons from stainless steel, but it is a lot cheaper to fit new calipers |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
New calipers all the way |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Perfect excuse to fit some brembos |
New cliper fitted (british car parts - £94ish delivered), should have changed pads, bit didn't. OSR still getting hot. Replaced pads as old ones, due to excees heat, had lost the backing. Took it for a hard braking test drive, all ok.
Got mine off the bay with no exchange for about £45-50 IIRC |
ABS could cause an issue but you would feel it grabbing as it was doing it...
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
It's also worth removing the disc and checking the parking brake shoes.
