Home > Maintenance & Mods (L322) > Supercharger pulley upgrade installed :)
Page 2 of 5 <12345>
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
The pulley is noticeable for about 2 weeks, then it gets coloured up and looks stock. I doubt a dealer is going to pull it off in the event of a warranty claim.
Really don't bother with the remap. There's a guy who is fitting twin screw kenne bell superchargers to our engines and getting 600+ bhp with the stock ecu.
If you do get it done, get the supercharger belt done at the same time to prevent slip.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #188692 16th May 2013 3:17pm
Thanks!
I've found a local Jaguar specialist and tuner who advertises the many S/C modifications and I had a long chat with him earlier. His prices are more reasonable and he knows the engines well.
He made an interesting point regarding the belt and oil. JLR, in their often infinite widsom have 'sealed' the S/C itself for life as with gearboxes. This chap says that at around 70,000 miles, the S/C's oil is pretty contaminated and WILL need changed to preserve performance and life. Si. <This is my name.
Post #188869 17th May 2013 10:41am
TheAllSeeingPie
Yup, I had my oil in the sc done at the same time as the pulley. It's a similar job to bleeding brakes, just needs bigger syringes Smile
Post #188875 17th May 2013 11:20am
ebajema
I probably need to get the SC oil done as well. Not only time but also the heat here are not great for the oil.
Better start diving into the workshop manual again Smile
Damn, should have done it when they were cleaning the injectors !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #188881 17th May 2013 11:35am
Another interesting tip the Jaguar chap told me regarding remaps on S/C's:
Apparently, some models will display an Error P0420 or 430 'Catalyst Inefficiency' message post-remap. According to the information given to me about this, the ECU has a VERY fine tolerarance for emissions values and even if out by a tiny amount, this message gets thrown up.
The engine check light illuminates and there is absolutely NOTHING wrong other than the tiniest degree of emissions over the pre-set values. Well within MOT guidelines, though.
The feeling is that this can be cured by injector cleaner and / or decent qualility fuel. The error can be frequent or very intermittent and it doiesn't affect all S/C's who have received remaps.
Has anyone who has had their S/C remapped experienced this? Si. <This is my name.
Post #188884 17th May 2013 11:48am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
In the States? 4.2 or 5.0?
Post #188894 17th May 2013 12:37pm
I cant find anything on the net about that but can find some jag guys uprating theirs to such things... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188900 17th May 2013 1:05pm
pld118
Cost to change gear oil?
How much incl VAT does it cost to get the S/C gearbox oil changed please (not having a modded pulley but this is an interesting point) ...
Thanks Thumbs Up
Post #188901 17th May 2013 1:05pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Found this on eBay!
http://www.ebay.co.uk/itm/Jaguar-Eaton-M11...0676739255 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #188933 17th May 2013 3:23pm
ebajema
I need to get hold of that oil Smile Have the syringe already and a plastic tube should be easy to find. Anyone have an idea of the specs ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #188952 17th May 2013 4:19pm
pld118
Excellent find.. Ebay ad reads like a DIY novice Embarassed could do it at home??
Post #188982 17th May 2013 6:02pm
RRBlue
More clues on spec:
http://www.jaguarforums.com/forum/xj-x300-...nge-80439/
Incidentally my dealer reckons ordinary 5W/30 will be fine!!!! 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #188986 17th May 2013 6:11pm
RRBlue
For me this is the safe option that I shall probably go for as it appears, from cruising various Jaguar and American forums, that the RR supercharger is the Eaton M112 (I may be wrong). Anyway, this stuff apparently does the trick for all Eaton blowers.
I shall call the suppliers tomorrow to find out more.
http://www.ebay.co.uk/itm/AC-Delco-Eaton-S...4ac3bbb3bb 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #189050 17th May 2013 10:08pm
TheAllSeeingPie
The eBay link for the oil is from Powerhouse in Sheffield, who are the guys who did my SC oil and pulley change.
I had a code thrown after my remap, cleared it with IIDTool and not had it since. The ECU takes the hint i guess. However I still think a remap is only needed if you make catalyst changes.
The guy with the twin screw is on the 4.0 and 4.2 engines and goes by the name of Avos on a load of jaguar forums. I'm still debating whether to go for a twin screw conversion or not, it's so temping but also so unnecessary. My RR absolutely hoons everywhere apart from the motorways, where it suffers from being as aerodynamic as Johhny Vegas when there's a headwind about.
Post #189202 19th May 2013 1:17am
This remap thing is my biggest conundrum.
The Jaguar specialist that mine will go to for the work has said that he offers clients to have the pulley done without the remap and then, after a few days, to install the remap for a free trial period after which he'll either remove it or the customer pays.
His comment was that he's never yet had to remove the new map. Si. <This is my name.
Post #189208 19th May 2013 7:44am
Page 2 of 5 <12345>
