Home > Maintenance & Mods (L322) > Supercharger pulley upgrade installed :)
Page 4 of 5 <12345>
That's just the pulley Stan Wink I mean including the above... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269240 5th Jul 2014 12:22pm
Embarassed Thumbs Up ... - .- -.
Post #269241 5th Jul 2014 12:24pm
I have a quick fix to gain an extra 10hp , buy a NAS spec supercharged . I have no ides why but American cars are rated at 400hp stock and ROW cars are 390hp Wink
Does any one know why ? 2008 MY Supercharged
Post #269256 5th Jul 2014 2:39pm
Fuel quality in the map?
Stick a NAS map on the car and see as it should have some more torque as well FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269259 5th Jul 2014 3:11pm
Philip
Fuel's pretty much the same - their 91 octane ((RON + MON)/2) is roughly our 95 RON, and 93 roughly 98.
All modern OEM ECUs advance and retard ignition to suit fuel anyway.
Post #269262 5th Jul 2014 3:51pm
We aren't talking about their fuel vs ours we are talking about US fuel vs ROW fuel Wink the maps have to accommodate this and it's not beyond possibility that the row and US engine maps are different in that the row is more conservative. Yes the ecu can adjust fuelling and timing but only within it's limits. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269275 5th Jul 2014 5:25pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
The car is currently managing around 384g/s for the mass air flow readings at about 5900 rpm, which equates to around 480bhp, but that's only if conditions are perfect, so the actual could be somewhere between 430-480 bhp. I'm about to route the air filter down near the floor to get colder air as the intake temps are around 40c when it's 20c outside, hoping to get this down to only +10c above ambient as it won't suck air from the top of the engine bay.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #269286 5th Jul 2014 6:17pm
Tasp don't move the filter down, it will just get more cack. Get one of those forced induction filter setups.
Like this but maybe a smidge bigger,
http://www.spoox.co.uk/en/c2/1129-citroen-...n-kit.html these are much better as you can sit it behind the grill and get cleaner air from next to the rads and higher up.
After this your really going to need to look at a CC setup to get the best use of space and all. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269290 5th Jul 2014 7:37pm
TheAllSeeingPie
Won't get more cack as it's still quite protected in there. The ITG doesn't have enough flow rate and would act as a restrictor. Even the BMC cdas are a bit dodgy really.
Post #269318 5th Jul 2014 11:47pm
So what you need is a bonnet scoop that feeds straight into one forcing even more air in Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269320 6th Jul 2014 12:06am
Philip
So why would the split be USA vs everyone else, given fuels are comparable across major markets?
Post #269344 6th Jul 2014 11:33am
The worst fuel in the states is 87. In row it can be anything as some will a test to. Especially in a country where it could have been sat in a tank for weeks and wasn't that good to start with. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269346 6th Jul 2014 12:02pm
Philip
So the US gets special ECU mapping which makes more power because you can buy crappy 91 RON fuel there?
Post #269350 6th Jul 2014 12:33pm
Logically speaking their lowest fuel is better than low fuels in the row region. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #269358 6th Jul 2014 12:51pm
Philip
... and the owner's manual will tell you to use 91 premium (which is equivalent to our our 95). There's 85 (89 RON) at the pump in the higher-altitude states.
Post #269359 6th Jul 2014 1:02pm
Page 4 of 5 <12345>
