Home > Technical (L322) > U0122 and several other faults...
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Sometimes you find that by clearing one ECU on the network of faults creates another issue because another ECU can no longer see it. In other words occasionally you will find clearing codes can create issues elsewhere. Perhaps this happened here?
You have to think of the CAN BUS as one entity rather than many separate ECU's. Confused
Post #187680 10th May 2013 9:19pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Do you know if it makes a difference when you do the lock to lock with the doors open or closed since when this started I did the lock to lock with the door open and it did not do the trick. When I later tried it again with the door closed it did... Weird, coincidence or what... Question Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #187681 10th May 2013 9:20pm
MikeG
WSIR, thx for elaborating on this... Appreciate your insights on this!! Will try to read and learn more on the ECU's and CAN BUS to better understand it all in the bigger picture. Mike.
Post #187682 10th May 2013 9:23pm
wslr
Doubt it is related. That sort of thing (Body control) will tend to be on another slower network. Your issues were on the High Speed CAN. Sorry but the 06MY is a little difficult to deal with as it was a real cross over year with the networks changing from BMW to the more traditional High/Medium/LIN/MOST Bus we know today. Rolling Eyes
Post #187683 10th May 2013 9:26pm
MikeG
Shocked all Abracadabra to me at this point... Need to do a lot of reading to better understand the systems in the FF... Mike.
Post #187685 10th May 2013 9:35pm
wslr
I'll see if I can find some diagrams at work to scan next week.
Post #187686 10th May 2013 9:41pm
MikeG
That would I really appreciate!! Thanks a lot for your help Thumbs Up Mike.
Post #187688 10th May 2013 9:45pm
wslr
No wucking forries. Wink
Post #187691 10th May 2013 9:49pm
Suspension will not function with the doors open, so it kind of makes sense that it will not reset with the doors open... Previously..
Post #187694 10th May 2013 10:07pm
MikeG
Hmmmm you got a point there... Whistle
Embarassed Mike.
Post #187696 10th May 2013 10:11pm
