Home > Maintenance & Mods (L322) > Gearbox oil change or not
Page 2 of 3 <123>
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
My car is now booked in for the oil change Thumbs Up
Post #187588 10th May 2013 12:03pm
let us know if it drives any better after the change.. Wink ... - .- -.
Post #187589 10th May 2013 12:05pm
Elena
I will Stan, although it may be in a couple of weeks time x
Post #187611 10th May 2013 1:56pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Get a gearbox update done at the same time. It resets the adaptions and really livens up the car.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #187628 10th May 2013 3:29pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Shocked
Gearbox update! hows that done? Is it software, ecu mod or a mechanical thing Very Happy
Post #189454 20th May 2013 5:54pm
wealy
Where are the instructions that you printed off Elena? I have searched but can't find them anywhere?
Post #202913 8th Aug 2013 8:27am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Mine has done 135k miles with no gearbox oil change and it is still smooth as silk on changes.
I have thought long and hard about flushing it but it seems to be a hung parliament on here about it. I have heard horror stories that it might encourage issues that the old oil is holding back. I change the engine oil on a regular basis but would hate to spend money on a gearbox oil change to only bring forward a box rebuild too. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #202918 8th Aug 2013 8:43am
hammiegt
I have the same quandary, mine is on 76k 2003 v8 rr, gearbox fine, don't know wether to change it or not, local autobox service center says yes, [owner runs a v8 rr] local indie says no, [owner runs a tdv6] what to do????????
my car has no towbar, but I will be fitting one as I will be towing my 1400kg caravan next year, which will obviously put a bit more stress on it, but if it aint broke!!!
cheers hammie 2003 ffrr v8 vogue
Post #213205 30th Sep 2013 2:40pm
nightster1
Ireland 2004 Range Rover HSE Td6 Epsom Green
ebajema wrote:
In the Wiki are the oil recommendations.
Things to look out for are metal shavings in the oil pan and on the magnets. I suggest to take a picture of the empty oil pan if there are any shavings to be seen and ask RRPhil is he reckons there are major issues by posting the pic on here.
Also the colour of the ATF (ask the mechanic to pour it into a clear plastic bottle so you can see the colour well). If it is quite dark and smells a bit "burned" then it was very much time to replace it.
Also you could feel the consistency of it, if it is still very slick/oily it is fine but if it starts feeling a bit "sticky" when you rub it between your fingers, it has deteriorated quite a bit.
All of these things are very subjective unfortunately. Having the ATF analysed is the best way to go but that goes a bit far to be honest. I mean the oil is out anyway.
Most important is correctly filling the box afterwards. So the car should be level, then the box should be filled according to procedure, run the engine for a bit and cycle through the gears 2 or 3 times (leave it in every gear for say 5 seconds) and then final fill with engine running in idle, in park and fill till it comes out of the fill plug hole. I don't know if the GM box also needs to have that done at a specific temperature, like the ZF needs.
Edit, cut and paste from the workshop manual : Draining and refilling the transmission is carried out via a drain plug, located in the sump of the transmission and a
refill/level plug located on the left hand side of the transmission. When checking the transmission fluid level the fluid
must be between 35°C and 45°C. Only Texaco ETL-7045E Automatic transmission fluid should be used for refilling /
topping up the transmission.
Forgive me for resurrecting an old thread, however my experience may be of benefit to some TD6 owners. I have my engine and gearbox fluids changed every 10K miles max. The engine uses nil oil between services. The level on the engine dipstick never changes. The gearbox is now 10 years old and operates faultlessly (to date) I have 110K miles done so far on it. The oil used is Texaco 7045E. The gearbox filter is changed every 20K miles. The old filter and oil are examined in detail after draining. No evidence of glitter in oil so far. I do get a phantom 'trans fail safe mode' on the dash a few times a year, which is a bit worrying.... Current:- TD6 HSE
Past:- Jeep Grand Cherokee Limited CRD x2
Jeep Cherokee Limited TD x1
Post #231471 26th Dec 2013 1:13pm
luckyrobp
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
My 2002 TD6 Vogue has 161000 Miles on the clock, Going to do a gearbox flush and filter change as it makes a harsh rumble noise at low revs and high torque. I only started hearing the rumble when heavy towing but it started to appear when not towing.
I bought the texamatic oil from fleet factors, 20 litres for £70.58 (£3.53/L inc VAT)
I am also going to remove the EGR and fit a speedhawk tuning box if they haven't been done
Post #234418 13th Jan 2014 1:00am
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
The problem is unless you have driven the vehicle from new you can't assess the state of the oil. Had mine changed this week and it was absolutely feeelthy (68k).
Post #234673 13th Jan 2014 11:59pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Bringing an old thread back to life!!
Parts ordered, I will be servicing my gearbox asap, and all the transfer boxes and diffs etc. I have been doing this for over 10 years on all my Audi ZF gearboxes and it's always helped to iron out any wrinkles and get things smooth again.
Post #533595 9th Nov 2019 7:23am
ur20v
A Trap
I can’t believe the question, it’s like say the engine is running fine why change the oil.
Just do it, the only reason not to is your selling it next week and even then it’s a great selling point being able to say gear box oil and filter have been done.
Post #533611 9th Nov 2019 11:35am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I’ve decided to do a gearbox drain and top up every time I change the engine oil. It only adds around 30 minutes to the normal service time and the cost of the 6/7 litres of gearbox oil is penny’s compared to a new box.
For the refill procedure buy a cheap laser/infrared thermometer off eBay for £7 to ensure you are at the correct temperature for the final top up.
Jim
Post #533612 9th Nov 2019 11:57am
WB
Here is the link to the ZF service method - this is very handy for the correct filling and torquing method as they differ between versions.
https://www.fullfatrr.com/gallery/albums/u...utines.pdf
Post #533620 9th Nov 2019 1:38pm
Page 2 of 3 <123>
