Home > Maintenance & Mods (L322) > Gearbox oil change or not
Page 3 of 3 <123
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
The guide you posted is for the older L322. The L405 has the 8HP70 I believe. Do you have a guide for this?
Many thanks
Kind regards
Post #533646 9th Nov 2019 6:03pm
Rambles
When you go through the gears......this is as straightforward as ensuring you apply the brakes whilst doing so?
Post #535061 21st Nov 2019 9:14pm
Charles89
Yes absolutely. No need to allow the wheels to turn. It's simply to allow the torque converter to fill with oil so you dont under fill the transmission Thumbs Up
Post #535062 21st Nov 2019 9:30pm
Rambles
Thank you
If you had a mega flush done, how many hours labour does it take including filter change at a garage? Between 2 or 3 maybe?
Post #535067 21st Nov 2019 9:36pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
ZL 8HP gearbox oil channe
My fullfat rr is a tdv8 2012 4.4 which is probably due for gearbox oil/ filter change. Can anyone tell me if a special tool for removal / refit of the filler plug Is really necessary. A tool re Lange Rover no 307-452 is mentioned in despatches but MD at Bristol can’t / won’t supply?
Happy to take it into my local garage with oil etc but wonder if they can do the job without this tool?
Any help appreciated.
Dave
Post #540889 17th Jan 2020 4:45pm
DrRob
Dave - take it to Cam Tech Craig’s place. Look him up on here Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540893 17th Jan 2020 5:11pm
Nylands
Thanks for that then , I’ll check thru the membership list. Been to wet etc lately to have a look under but a good time to plan the next jobs. Spoke to nearest MD and they quoted over £200 just for the sump pan?
Cheers
Dave
Post #540898 17th Jan 2020 5:29pm
craig is your man,
https://www.cam-tech-landrover.co.uk/ ... - .- -.
Post #540903 17th Jan 2020 5:37pm
DrRob
Take it to Craig and relax knowing it will be done right and not at main stealer prices Banging Head Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540906 17th Jan 2020 6:09pm
Nylands
Thanks for the link and found his web site. I’ll give him a call next week for a chat. Mislabel at 51000 but now seven years old .
Thanks guys
Dave
Post #540920 17th Jan 2020 8:10pm
Page 3 of 3 <123
