Home > General > Flat Battery...AGAIN! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Well, it seems that my battery just could not cope with the Pre Heater this morning. I switched it on and after half an hour went to leave the house, it's as flat as a flat thing again. So, the AA are coming out to jump start me but I think I'll have to get this replaced ASAP. (Especially as I like using the pre heater on cold mornings)
16th Dec 2008 8:53am |
Prices gained so far vary wildly, looks like I'll be going down to my local independent again as they have come up trumps.
16th Dec 2008 9:20am |
3 years and 7 months . Discovery 4 HSE
16th Dec 2008 12:06pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
Thats ok. When you said flat battery again i assumed it hadn't lasted long |
16th Dec 2008 12:11pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
you could also try an agricultural machinery dealer - around the £75 to £80 ex VAT mark. They are the same size battery as some tractors, but just make sure the terminals are in the same place. |
17th Dec 2008 12:16pm |
Went down to my local indy garage this afternoon, they replaced the battery and also rebalanced my front wheels for free. (Yet to see if this has worked as only got country lanes between me and them)
18th Dec 2008 5:37pm |
Hope it was a Pirelli calendar |
19th Dec 2008 12:31pm |
Sadly not, just has pics of supercars on it.
19th Dec 2008 1:54pm |
that does it, I'm ordering one. Saved the images of each month to my desk top and zoomed in |
19th Dec 2008 3:53pm |
Wheel vibration much less than before but still noticable on braking wonder if the replaced front discs I had done a few months back have slightly warped? Discovery 4 HSE
20th Dec 2008 11:10pm |
Find it strange to be your discs especially since you have just had your wheels balanced . when you changed your discs did you change your pads as well ........... |
21st Dec 2008 2:11pm |
If its a warped brake disc then it will get significantly worse when you apply the brakes - otherwiose likely to be a wheel warped, out of balance or possibly a bearing. |
22nd Dec 2008 10:18am |
Yep, front discs and pads changed at the same time.
22nd Dec 2008 10:21am |
warped disc imhe |
22nd Dec 2008 10:37am |
