Home > General > Flat Battery...AGAIN!
Well, it seems that my battery just could not cope with the Pre Heater this morning. I switched it on and after half an hour went to leave the house, it's as flat as a flat thing again. So, the AA are coming out to jump start me but I think I'll have to get this replaced ASAP. (Especially as I like using the pre heater on cold mornings)
I'm going to ring round my local dealers and an independent to see what the prices are like but I'm going to guess at the thick end of £200, maybe more who knows. Discovery 4 HSE
Post #1846 16th Dec 2008 8:53am
Prices gained so far vary wildly, looks like I'll be going down to my local independent again as they have come up trumps.
Bare in mind, these things have HUGE batteries, they are almost truck size, at least double the size of a standard car battery.
here's the votes so far:
Local dealer 1: £131 all inclusive
Local dealer 2: £157 all inclusive
Local Indy garage: £90 all inclusive Discovery 4 HSE
Post #1850 16th Dec 2008 9:20am
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
I bought my replacement at an independent and it was significantly cheaper including fitting etc... which as i have mentioned in previous feeds is a pain due to size and weight etc..
How long did this battery last ?
Post #1851 16th Dec 2008 12:04pm
3 years and 7 months . Discovery 4 HSE
Post #1852 16th Dec 2008 12:06pm
Full fat not diet
Thats ok. When you said flat battery again i assumed it hadn't lasted long
Post #1853 16th Dec 2008 12:11pm
Vogue
you could also try an agricultural machinery dealer - around the £75 to £80 ex VAT mark. They are the same size battery as some tractors, but just make sure the terminals are in the same place.
Post #1867 17th Dec 2008 12:16pm
Went down to my local indy garage this afternoon, they replaced the battery and also rebalanced my front wheels for free. (Yet to see if this has worked as only got country lanes between me and them)
Not only did it only cost me £89.95, they also gave me a free 2009 calendar!
Great service from Tanvic Tyres, Melton Mowbray. Discovery 4 HSE
Post #1885 18th Dec 2008 5:37pm
Vogue
Hope it was a Pirelli calendar Cool
Post #1893 19th Dec 2008 12:31pm
Sadly not, just has pics of supercars on it.
however i did get this calendar from my secret santa at work!
http://www.gunsandcamo.com/ Discovery 4 HSE
Post #1894 19th Dec 2008 1:54pm
Vogue
that does it, I'm ordering one. Saved the images of each month to my desk top and zoomed in Twisted Evil
Post #1897 19th Dec 2008 3:53pm
Wheel vibration much less than before but still noticable on braking wonder if the replaced front discs I had done a few months back have slightly warped? Discovery 4 HSE
Post #1937 20th Dec 2008 11:10pm
Find it strange to be your discs especially since you have just had your wheels balanced . when you changed your discs did you change your pads as well ...........
Post #1942 21st Dec 2008 2:11pm
Vogue
If its a warped brake disc then it will get significantly worse when you apply the brakes - otherwiose likely to be a wheel warped, out of balance or possibly a bearing.
Post #1956 22nd Dec 2008 10:18am
Yep, front discs and pads changed at the same time.
While driving there is no steering wheel wobble at all, which would suggest to a sane mind that the wheels are balanced correctly. When I'm doing over 60 mph and I feather the brakes gently rather than stomping on them, the steering wheel wobbles slightly. The car does not pull to one side.
It wouldn't be the first time that a brand new part has been at fault, if one of the discs is just slightly 'out' then this would explain the problem. My M5 went through front discs like they were made of wet cardboard, they're notorious for warping discs as they calipers were not up to the job and everything overheated and went pear shaped. I know what warped discs feels like and this is getting more and more like it!
Will give it till the new year then decide if its worth looking into again. A new set of discs are not expensive and fitting is all of an hours labour. Discovery 4 HSE
Post #1957 22nd Dec 2008 10:21am
Vogue
warped disc imhe
Post #1960 22nd Dec 2008 10:37am
