Home > Maintenance & Mods (L322) > Seatbelt Tension on Facelift RR |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
Allllllll seatbelts ever made do this, it's just age, or crap and dust mixing with the grease in the winding spring.
5th May 2013 7:46am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Yes they do go faulty alot... Two things to do, Remove the B pillar cover and clean the seatbelt guides (little aluminium bars) as they do get covered in a sticky thick dust... if that fails to work then change the belt (which we do as well as cleaning the bars usually) Belts are a very reasonable £65, hence why we tend to change the belt at the same time as cleaning because of the labour time...
5th May 2013 7:51am |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
Silicon spray |
5th May 2013 7:52am |
Very helpful.. Cheers |
5th May 2013 7:56am |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Ive been quoted £256 by a dealer to fix mine! Does anyone have any guides on how to do it yourself? |
5th May 2013 8:29am |
An easy DIY job Remove the B pillar cover,,, Tork screws and clips, remove the seat belt and replace There are no pyrotechnics in the seat belts so no airbag worries... Craig |
5th May 2013 9:08am |
Thanks Craig, I had a real fear of a sudden unexpected explosion!
5th May 2013 9:20am |
