Home > In Car Electronics (L322) > Rear camera 2005 square headlights, touch screen
Robbieowens
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
Hi, I've done a search and found conflicting info about how retro fit a reversing camera into a 2005 square headlight, touch screen model. Depending on what I've found, it can't be be done, it can be done but you need to configure the head unit to allow the aux input, it can be done and you don't need to do anything other than connect power to reverse light and connect the input to the head unit
Has anyone actually managed to get this to work and if so, how was it achieved?
I found this on eBay [url] http://www.ebay.co.uk/itm/BMW-Car-Reversin...a361[/url]
Would this be suitable?
Advice appreciated before the wife reverses into another skip Wink
Post #186512 4th May 2013 11:46am
daveo
you can fit the reversing camera to them all from the very first late 02 onward, what year is yours V8 facelift Range Rover Autobiography 22" wheels.
Post #186517 4th May 2013 1:07pm
daveo
sorry just read your post again, ok you have a 2005, no prob,,, but that camera on your link wont fit, thats designed to go in your number plate lights and it is not a straight fit...get a camera to fit under your spoiler, you need a ntsc camera, do you have a tv tuner... V8 facelift Range Rover Autobiography 22" wheels.
Post #186518 4th May 2013 1:11pm
Robbieowens
Thanks, I have an analog tuner I assume as I can't get tv pictures, can the input connect into that?
Post #186534 4th May 2013 3:47pm
daveo
with one of these
http://www.ebay.co.uk/itm/BMW-3-5-X5-Range..._768wt_934
you and use the aux in on your screen, the lead goes in line and allows you to feed a video sorce in, when you select reverse, with the ade of a small relay you ground out pin 17 on the white vide plug on you tv tuner and this will switch your screen to and bingo rear image..
just double that its the white plug.. V8 facelift Range Rover Autobiography 22" wheels.
Post #186553 4th May 2013 5:55pm
Robbieowens
Ok thanks or the info, however isn't the 2005 touch screen the most system and the eBay item is for I-bus.
Post #186558 4th May 2013 6:12pm
Robbieowens
Has no one fitted a reverse camera to a 2005 touch screen, square headlight range rover? Your help would be appreciated I don't want to buy incorrect parts
Post #187028 7th May 2013 11:51am
i looked into it and found that the only way to get the screen to switch on when reverse gear was selected was to get an after market module which cost approx £400 or maybe get it switched on in the ccf . ... - .- -.
Post #187030 7th May 2013 12:01pm
Robbieowens
Thanks Stan, I'll guess I'll give it a miss then....£400 seems too much money just to have a reverse camera
Post #187033 7th May 2013 12:07pm
just remembered that there was a company selling modules for about £150 said to be ok for the fullfat but there was doubt whether it would do the job..i'll try and dig up some info.. ... - .- -.
Post #187034 7th May 2013 12:11pm
it was a gvif interface that gave you a dvd input and camera when reverse was selected but as far as i can remember i couldnt find it for the fullfat , only for the sport and evoque.. ... - .- -.
Post #187036 7th May 2013 12:17pm
this might help.
http://www.disco3.co.uk/forum/topic49789.html ... - .- -.
Post #187037 7th May 2013 12:20pm
Robbieowens
Interesting reading however still pretty expensive IMO, I guess the sensors will just have to suffice, thanks anyway
Post #187039 7th May 2013 12:36pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I have not installed the camera, but I have a pre facelift touchscreen L322 and you can activate the camera mode using the IID tool.
When I select reverse the screen changes automatically to the reverse camera (which is blank as no camera is installed, but it does have the warning text about reversing).
I have the cable and a rear spoiler to install to test it out, but it looks like the system can be switched on easily. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #187043 7th May 2013 1:00pm
Robbieowens
That's better news, just need to find an auto spark who has the IID to turn the option on and find the camera, do you definitely need the rear spoiler with camera or can you retro fit any camera in? Perhaps in the rear bumper?
Post #187044 7th May 2013 1:04pm
