![]() | Home > Maintenance & Mods (L322) > Problems with engine 2006 4.4 Start the car, and turns off.. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
You can run the engine with the MAF disconnected, try that see if it makes a difference |
Sounds like a fuel issue. I had it before I changed my fuel pump and the injectors/fuel line/inlet manifold were cleaned.
Fatandre Member Since: 05 Nov 2012 Location: Iceland Posts: 8 ![]() |
Do the headgaskets go often on the jag engines? |
Stroker Member Since: 03 Jul 2012 Location: Switzerland Posts: 3 ![]() ![]() ![]() |
sounds like a blocked crankcase vent. |
Good point, could very well be something like this. I remember the BMW engine has some issues in that field with the PVC valve etc. MY 2010 5.0 SC Galway green and sand interior!!
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
Stroker's probably got something there. |
