Home > Maintenance & Mods (L322) > Problems with engine 2006 4.4 Start the car, and turns off..
Fatandre
Problems with engine 2006 4.4 Start the car, and turns off. I turn it on, and have to keep the throttle up with the gas pedal, there came lots of smoke, maybe bluish. This has been for the couple of days when it stands over the night. Then after I drive it all is good and no smoke and no blue or dark ( I am though not sure how the color is after cold start)
Engine is driven 100k miles. Could it be the maf?
Also when I rev the engine and let it drop the rpm falls to 500 like it almost turns off and then gets stable again.
Post #185763 30th Apr 2013 11:09am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
You can run the engine with the MAF disconnected, try that see if it makes a difference
Post #185766 30th Apr 2013 11:37am
ebajema
Sounds like a fuel issue. I had it before I changed my fuel pump and the injectors/fuel line/inlet manifold were cleaned.
I suggest to start with the cheaper stuff, chuck injector cleaner in and make sure you use good quality petrol. Then proceed with cleaning the inlet manifold, next the injectors etc. Also suggest to change the fuel filter. MY 2010 5.0 SC Galway green and sand interior!!
Post #185773 30th Apr 2013 1:24pm
Fatandre
Do the headgaskets go often on the jag engines?
Post #186057 1st May 2013 6:38pm
Stroker
Switzerland 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
sounds like a blocked crankcase vent.
Post #186079 1st May 2013 9:07pm
ebajema
Good point, could very well be something like this. I remember the BMW engine has some issues in that field with the PVC valve etc. MY 2010 5.0 SC Galway green and sand interior!!
Post #186084 1st May 2013 9:19pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Stroker's probably got something there.
Post #186086 1st May 2013 9:20pm
