Home > Maintenance & Mods (L322) > Problems with engine 2006 4.4 Start the car, and turns off.. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
You can run the engine with the MAF disconnected, try that see if it makes a difference |
30th Apr 2013 11:37am |
Sounds like a fuel issue. I had it before I changed my fuel pump and the injectors/fuel line/inlet manifold were cleaned.
30th Apr 2013 1:24pm |
Fatandre Member Since: 05 Nov 2012 Location: Iceland Posts: 8 |
Do the headgaskets go often on the jag engines? |
1st May 2013 6:38pm |
Stroker Member Since: 03 Jul 2012 Location: Switzerland Posts: 3 |
sounds like a blocked crankcase vent. |
1st May 2013 9:07pm |
Good point, could very well be something like this. I remember the BMW engine has some issues in that field with the PVC valve etc. MY 2010 5.0 SC Galway green and sand interior!!
1st May 2013 9:19pm |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
Stroker's probably got something there. |
1st May 2013 9:20pm |
