![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
the IIDTool has the ability to adjust the volume of the parking sensors so there's a possibility that it could re-activated your beep.. ... - .- -.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Tool will not allow configuration of the BMW ECU .... Probably due to slightly different firmware. |
cold and hot monitoring should be in the 'lcm' menu.. ... - .- -.
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
Steve, just checking before I order one... I have a model 2006 TD6 (Vin starts with A6......) but it was delivered in August 2005. If I have understood all posts on here and the information on your site correctly then I should be ordering the IID for the 2006 - 2009 model, despite the FFRR being delivered in 2005, correct?
Mike, if you post a photo of your screen in the car. That is one of the best indicators. The touchscreen version has fewer and different buttons on the MY2006 and up.
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
I have a similar vehicle registered 05 but 6A chassis so ordered the 2006-2009 and it works fine |
It's a touchscreen so must be the 2006 then... See picture.
Thx David!! |
Mike, vins that start with a6 require the 2006 onwards IIDTools... ... - .- -.
Great, thx Stan for confirming I require the 2006 onwards... I like the fact the IID is small and can be stored in the dash so at hand when needed. Appreciate the help!! |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Tried looking in the LCM menu and there is nothing there, lots of options for follow me home etc but not a single CM or HM. Maybe it is not available on the 2002-2005 model. Tom Current Drive 2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather Previous Drives 2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather 1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather 1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic |
there's a drop down select menu on the GAP site and these functions are there...no doubt Steve will be on soon to help. ... - .- -.
I contacted Patrick and he told me to uninstall the old updater and install the new one you will have to contact them directly if you need it although you should be able to get it from their site.
big thumbs up for the gap team |
