Home > Technical (L322) > Won't start - Immobiliser problems ?
Page 4 of 4 <1234
ebajema
Glad it was something simple !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #150032 6th Nov 2012 8:01pm
The problem with these switches is they are sitting where they can easily get loads of crap dropped into them
Post #150052 6th Nov 2012 9:03pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
but they also sell the piece, or even the whole kit locks?
Post #151535 16th Nov 2012 2:15pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I have started having some problems with what I think is the ignition switch.
The starter motor has been checked and seems ok. They have moved back to the ignition switch but as it is an intermittent fault it cannot be repeated.
I have been quoted 440+vat+testbook+something+something (totalling 700+ & al long wait) for a "whole lock kit".
Reading this thread it seems that the barrel only can be replaced and every lock and key.
Would anyone have a parts numbers that I can quote to the mechanic and ask why the full replacement?.
Many thanks in advance.
Post #181426 5th Apr 2013 12:42pm
madcima
hi, all you need is the part code under the key lock, or locks the entire kit?
Post #181427 5th Apr 2013 12:45pm
DavidP
Hello,
both would be great
the garage is saying that the part is only available as a full lock kit.
Rgds
Post #181430 5th Apr 2013 1:07pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Had the same Problem at a clients car, it was the steering lock in the steering column, build it out, and opended the box with the lock, the parts are not to buy, but I recon all parts, build in the column, and all is ok. Landrover itself wante to sell a new column, 4.000 Euro plus Fixing! A Picture Shows the parts.
[/img] L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #348325 18th Sep 2015 6:42am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I came across this gem of information
http://www.blackbox-solutions.com/photos/L322lock.pdf
Basically it shows you where to drill and squirt WD40 - also RSW AllComms has something on his site about the interlock.
Hope it helps.
Good luck and let us know how you get on - I am thinking of doing a pre-emptive strike against mine - on my TO DO list.
Bon voyage. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #348360 18th Sep 2015 9:04am
Meerbusch
@smutt, thank you very much for this article, but I know it, is no good solution, because you can drill to deep, or at a wrong Position, then the Solenoid ist defect. Better to build out and recon the Solenoid, mostly inside broken. Thegood RSW Storey has a good Picture from the lock, but has also no solution for it. So believe me, best way, build out and renew the Solenoid. Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #348378 18th Sep 2015 11:01am
SMUTT
Hi Uli
Thank you very much for the information.
How did you cut your steering lock open? (eg Angle Grinder, Hacksaw?)
And where did you cut? (did you have any pictures?)
Many thanks for your time - I am sure others would be interested Howard
Post #348382 18th Sep 2015 11:19am
Meerbusch
After build out the whole column, I open the shape of the metallbox near the steering wheel, there are six Little black Splint, like screws, and after open, you will se the Solenoid, you can take him out easy. You have to Change or recon him, then all in the other way retour. Best rgs L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #348383 18th Sep 2015 11:44am
SMUTT
Thank you very much for sharing the information Smile
A nice evening project for the kitchen table now the days are getting shorter. Smile Howard
Post #348393 18th Sep 2015 1:15pm
Page 4 of 4 <1234
